Question about Brother LS-2125 Mechanical Sewing Machine
Timing problem how do i reset the timing on my sewing machine? i've been told it cost alot to have someone fix it and i should take it back to the store to trade for a new one. but i want to at least try to fix it myself before giving up. its only a couple years old and i have used it twice. can you help me so i don't have to lie to someone to get a new one?
  • 2 more comments
  • keketwin Jan 23, 2008
    i have tried that but still won't hook. is there a manual for my ls 2125 brothers sewing machine to help me fix it?
  • keketwin Jan 27, 2008
    ken i tried emailing you but it didn't work. do you have a email that will work for sure?
  • scherokee Feb 10, 2008
    Can you send the instructions for retiming my LS-2125 to me? My email is
  • 1248 May 05, 2008
    I need to retime the shuttle, how do I do this.
  • 397 Answers
Needle cusp and hook have to work simultaneously in order to form a stitch, when needle is going up hook is coming past the needle cusp to lock the stitch, make sure that is happening first
Posted on Jan 21, 2008
Singer confidence quilter beeps 8 times won't sew
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
I have a Bernina B380 on the first stitch it sounds like metal hitting metal what's wrong.
If it is the very first stitch after the machine is turned on, then it's just the stepper motor for the feed dogs centering itself. This is normal for computerized machines. If it does it every time you start a new seam, then you are dealing with something different.
May 14, 2012 | Bernina Sewing Machines
Sewing machine electrical problem
Improve the FixYa experience for everyone by voting.
You have cooked your motor. Someone should have told you to bring a converter since most former British Colonies operate on the European 220 volt, 50Hz system.
I've spent a lot of time in West and East Africa and discovered that there is always a local craftsman who can do such things as rewire a motor, convert it to 220, or even sell you a converter.
The alternative is to purchase a new motor from Kenmore and have it installed locally if you don't want to do it yourself.
CLICK HERE for Sears Parts Direct.
All the best and thanks for all of good work
May 14, 2012 | Sewing Machines
My Bernina 1230 won't shut off. I need to unplug it each time.
I agree about the on & off switch, it could be going out or have a short in it
Apr 05, 2012 | Bernina Sewing Machines
Janome Gem 760 sewing machine: needle hits bobbin casing
from what I've read that you've put down it sounds like the machine is out of time, which means it needs to be fixed at a sewing machine repair shop
Feb 08, 2012 | Sewing Machines
My singer 1120 sewing machine needle will not move. When I press the foot pedal the motor makes a sound but the machine will not sew. The machine will sew if I crank the hand wheel but it is very...
I presume that you have checked that the clutch to wind bobbins is reengaged?? It is easy to forget sometimes. If your machine has a knob inside the flywheel to do this, then just check that it is fully tighted back up to reenage the motor drive.
Otherwise it may just be the drive belt has worn/broke/is slipping internally. I wouldn't dump it just yet, it may well be repairable.
The motor belt is available here so if parts are on the market then it may well be worth taking it to a repair shop and getting a quote to fix it. Depends on how long you've had the machine and what you paid for it and the cost to repair vs buying a new one.
If you or someone you know is technical, they may want to have a go at opening up the case and seeing what is happening around the drive/flywheel area - just make sure everything is disconnected from the power first.
Sep 07, 2011 | Singer 1120 Mechanical Sewing Machine
I've had my Tacsew machine for 5 years. The oil has never been changed and the com. that sold it to me is out of business. I bought oil from the business but he never told me when to change it. Can...
Industrial sewing machine oil is usually not brand specific but is not interchangeable with automotive motor oil or thinner lubricants. Do not use WD40 or similar type lubricants as a substitute! Check with a local sewing machine repair shop or order online from (search for industrial sewing machine oil) This type of oil should cost less than $15 for 16 oz (before shipping)
May 14, 2011 | Tacsew Sewing Machines
I bought this portable cs6000i sewing machine at Walmart for $139.00 and I am now told that it has to be taken to a service center to be cleaned and lubricated. This is a cost of about $59.00. There was no...
I have this machine for over 2 yrs now and I take the bobbin case out and clean there and put a few drops of oil in the middle where the metal thing is. Someone told me not to oil it but I do and it runs great. I also oil where you see the moving parts around the bobbin case. Don't sew jean hems on it as I wrecked my feed dogs. I just ordered a new machine because I got my money out of that one. Love it! Jan
Dec 26, 2008 | Brother CS6000i Computerized Sewing...
Brother CS-6000 Sewing Machine - Jam
I have the same problem and found that the bobbin case is scratched. These are quite expensive so I hope yours is something more simple. Keeping the bobbin area clean is also a necessity.
Jul 28, 2008 | Brother CS-6000
Will not run
I had the same problem with my machine, there is nothing you personally can do to fix it. You'll have to find a service tech who can work on it to solve the problem.
Dec 23, 2007 | White Sewing White 4400 Computerized...
Brother LS-2125 Mechanical Sewing Machine Logo
77 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
