Sub-Zero 632 / S
Problem for Sub-Zero 632 / S
Service code EC?
By nov2602 on Jan 21, 2008
Does anyone know what that means?
Same Problem
Feb 14, 2008
-   I have an error code ec06 on a sub zero 632. Any ideas?-   Louietrev
Best Solution
posted on Jan 21, 2008
Very Helpful)
Master_Tech
Rank: Guru
Rating: 88%, 773 votes
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 15, 2009
Not Rated)
greggalf1
Rank: Apprentice
Rating: 0%, 0 votes
"EC" means "error code". The code itself is the flashing number that alternates with the freezer temp display.
The meaning of the error codes was posted above.
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 632 / S
Questions and Unsolved Problems for Sub-Zero 632 / S
Do you recommend Sub-Zero 632 / S?
Answer
Answer
refrigerator is not cooling but freezer side is
Answer
Water pooling in bottom of refigerator side alreadyreplaced the door seals
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 632 / S:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
