Question about Zebra S4M Thermal Label Printer
Alert code My S4M printer "alert" light blinks all of a sudden. We've been using it for a year and suddenly the light blinks. We haven't changed any settings or media. We cannot print to it.
  • 2 more comments
  • animalar Nov 11, 2008
    My S4m Printer "Alert" light blinks all of a sudden. It prints nothing and the LCD displays says "Printer Paused data" and it stops middle of the label
  • katfisch70 Nov 25, 2008
    My printer (Zebra S4M) says: Alert Ribbon out, but I have no clue how to solve this problem. What ribbon and where do I change it?
  • Anonymous Dec 19, 2008
    most everything we try does not work. there is ribbon loaded.. we open and close the header and occasionally it works again. But what can fix this permanently???
  • Anonymous Jan 09, 2009
    Alert light keeps blinking everything is installed find but machine won't print
    Problem Solver:
  • 13 Answers
What is the message that should be display in the LCD display? The Alert light signals a problem the printer thinks it has and usually display amessage in the LCD display to help a user determine what may or may not need repair or service.
Posted on Feb 02, 2008
What is the blinking light at the to of the phone after a vibration alert
being as your basically in silent mode, the blinking light gives you a visual alert, in case you dont feel the vibration.
Jan 24, 2012 | Motorola Mobility MILESTONE Cell Phone
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
May 18, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
Printer is paused alert ribbon out, but we don't use a ribbon
Sounds like you're just in the wrong printing mode. Go into your front panel setup and search until you see
Press the arrow buttons until it says DIRECT THERMAL, then save and exit.
Apr 05, 2010 | Zebra S4M Thermal Label Printer
S4M .how to do when it show alert massage
Are you using a ribbon? If so, then the ribbon is not loaded correctly passed the ribbon sensor. Or, the media is loaded in this position. Check the diagram on the inside of the door to make sure labels and ribbon are installed correctly. If you are not using ribbon, then you need to set the printer to direct thermal in the front panel and/or the software.
Oct 13, 2009 | Zebra S4M Thermal Label Printer
Seems like your Printhead needs to be replaced.
I have new 3rd party in stock at this time if needed.
Please contact me back.
Rory Cardenas
Midrange Repair and Parts
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
Jul 29, 2009 | Zebra S4M00-2001-1100T Thermal Printer
My zebra printer s4m is saying ALERT CLEARED HEAD OPEN, ALERT RIBBON OUT
Alert Head Open will show everytime u open the Head , when u close back the head it will show Alert CLeared Head Open, then it's normal.
Ribbon Out Show means the printer doesn't detect a ribbon, make sure there's nothing wrong with ribbon installation. if everything fine, then the problem is you Ribbon Sensor. u can try to adjust the sensor with a screwdriver ( - ), make a little bit higher
Jul 11, 2009 | Zebra Thermal S4m Dt Zpl 203dpi Rs232/par...
Alert 450R - Lights Won't Flash Anymore
is your parking light wire, wired positive or negative. If positive check the fuse on the input wire for the parking lights on the remote start. If thats not the problem check the connection of the parking light wire,should be a whiite 16 gauge wire, to your car lights. If thats not the problem then they output for the lights is bad and you'll have to get a new brain.
Feb 19, 2009 | 450-R Deluxe Remote Starter with Keyless...
How to reset factory default S4M. I try Pause and feed at starting the printer but it does'nt works. I have a display message: ALERT RIBON OUT.
This may be related to the printing mode you have configured. If you're printing on a thermal paper (direct) and the printer is configured for thermal transfer the printer will notify you that you are out of ribbon.
If you are printing on a regular paper and using a ribbon (thermal transfer) and the printer is configured for direct printing, the printer will notify you that you have a ribbon when you don't need one.
I hope this helps.
Jan 13, 2009 | Zebra S4M Thermal Label Printer
Light won't turn off phone flashing
I hope this will help. I had the same problem with the message alert light not turning off. I have phone service through the internet. I would clear messages from my base unit and alert would continue to flash. I went into my internet message center and found a few old messages there. Why they got there is beyond me, but after clearing them my alert light went out and stayed off. I disabled messages to internet inbox and now it flashes only when I get messages to my base unit until I listen or clear them. Easy fix to annoyance I've had for some time.
Nov 19, 2008 | Uniden TRU9480 Cordless Telephone
Zebra S4M Thermal Label Printer Logo
779 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
