Question about Whirlpool GGQ8831L Gas Dryer
Whirpool Dryer...... It seems to be running fine,the lint screen is clear,have opened it up and taken the back off..no excess lint build up,dryer vent tube is clear.....taking two hours to dry one load,normally only takes 50 minutes to dry one load.... Any suggestions? Thanks!
  • leera Jan 21, 2008
    Forgot to add,it's a gas dryer.....thanks.
  • leera Jan 22, 2008
    Already checked that....that was one of the first things I did...any other suggestions?
  • 770 Answers
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Posted on Jan 21, 2008
  • Gary Davd
    Gary Davd Jan 22, 2008
    ok if you have ran the unit with no vent on and still have the problem it could be your cycling thermostat. also it could be a gas valve issue where the ciols is dropping out and shutting down the heat you will need to call a service tech to resolve where the problem lies Hope this helps
Gallery
First thing is to check that your dryer is venting properly. If it is restricted this may occur. There are vent cleaning kits that you can purchase to make it easy to clear your vent from the rear of the dryer to the outside exhaust. Check were your link screen slides in at and inspect it for excess link build up. Any more questions you can contact us a dryer repair service.
May 20, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Dryer functions seem normal, barrel rolls, air is circulating and it feels hot, however clothes are not dry after several cycles/hours.
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Mar 06, 2011 | Whirlpool LEQ9858P Electric Dryer
Turn dryer on and it starts to heat up and then the heat stops and within about 2-3 minutes will start to heat up and then the heating up stops.
Clean out the exhaust vent tubing really good.. A moister sensor will detect any build up of lint and shut the heat off
Jun 03, 2010 | Dryers
I have a kenmore 76712. clothes only gets warm but does not dry even after 3 cycles. I have looked in the back cabinet and i see the ignition working and lighting up. But it goes off after about 5-8 secs...
The unit must be taken apart to clean. Also the duct work (vent tube) will have to come completely apart for those tubes will be solid full of lint as well. That is why the dryer is not drying your clothes. I guarantee you will find a handfull of lint for every foot of tubing you have. OInce cleaned the dryer will operate like new again
Apr 21, 2010 | Dryers
Cloths take way too long to dry. Heat is working in dryer. Timer works, counts down from 60 min, buttheremo drying timer takes way too long.
You will need to check the dryer venting system for a restriction. If there is a restriciton in the venting system the dryer will get hot but the clothes will stay wet due to the moisture never leaves the dryer. First check the air flow at the vent exit located outside. Verify that there is plenty of airflow. Make sure the vent screen is not plugged. Then remove the screen and visually inspect for excessive lint. Then go inside and check the moisture vent hose behind the dryer. Verify that the vent hose is not kinked or restricted. Then remove the hose and clear out any excessive lint. Then check the vent opening at the back of the dryer for any excessive lint build-up. There is a vent cleaning kit that you can purchase from any home improvement store that you can use to clean out the venting system also. When you are done airflow should be good and clothes should properly dry.
Jan 22, 2010 | Maytag Dryers
Dryer overheats and shuts off
A common problem for the dryer overheating is due to a restricted moisture vent. First check the vent hose and make sure it is not kinked or restricted. Then pull the hose off and check for excessive lint. Pull any lint you find inside the dryer vent opening and in the moisture vent hose. Then verify that you are getting plenty of air flow from the vent exit outside. It is possible that you have excessive vent build-up between the wall to the outsied on the venting system. There is a kit you can buy for cleaning this system. If everything is clear then there could be a problem with the dryer thermostat.
Dec 24, 2009 | Frigidaire Dryers
Dryer is not drying. Lint is not collecting on
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust.
However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. With a clog comes condensation and longer dry times. The dryer will continue to run inefficiently and cause the heating circuits to work harder and overheat. This will eventually lead to a failure of the heating circuits. If you are seeing condensation inside the dryer, it is strongly recommended the you inspect and clean the dryer exhaust vent hose. You should repeat this a couple of times a year to ensure it remains obstruction free.
The most frequent causes of dryer vent clogs comes from the following:
1. Ducting that runs in an upward direction in homes that have an attic exhaust. This is a stupid design that gravity will always win. When the dryer shuts offf, anything left in the vent will fall down the ducting to the base of the wall and accumulate. Over time, this forms a clog.
2. Ducting that runs under the home in a crawl space. If not correctly hung from the rafters, the ducting will develop sags causing choke points where lint can accumulate. Leaving it on the ground is not the answer, either. This gives opportunity for rodents to possibly chew through it. This will cause leaks which exhausts warm moist air under your home resulting in mold and mildew.
3. Using plastic dryer vent hose. This type of hose is not recommended because it kinks easily and can get crushed, causing an obstruction where lint can clog. Rodents can also chew through it easily. Pushing the dryer up against the wall and crushing the hose is a common cause. Use the semi-rigid metal type ducting that resists crushing, kinks and rodent infestation.
4. Rodents. Mice love lint. If given the access to it, they will build inside the dryer vent hose which provides a nice warm place to live with lots of bedding material. Make sure you exhaust vent on the exterior of your home is about 12 inches from the ground.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not become clogged.
6. Excessively long vent hose. The rule of thumb when it comes to dryer vent ducting is: The SHORTER and STRAIGHTER the run, the BETTER. Excessively long dryer vent hoses will clog due to the fact that the blower fan is not able to push all the air and lint all the way to the exhaust.
7. Kinked, Excessively Bent, or Crushed vent hoses. If the vent has any choke points due to kinks, bends, or gets crushed behind the dryer, you will develop ponts where the exhaust vent will clog.
The following link may also help in providing some basic guidance on how to install dryer vent hose:
http://www.fixya.com/support/r389357-dryer_ducting_installation_tips
I know it may seem that I'm beating this point to death, but it is important to provide good air flow for your dryer. The number one cause of dryer failures and house fires comes from poorly maintained and poorly installed ventilation ducting.
If you have any questions, please let me know. I hope you find this information helpful.
Sep 07, 2009 | Dryers
The lint screen does not capture lint. The lint
To dispell a common myth. There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust. However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. It is strongly recommended to have the exhaust vent hose checked and/or cleaned a couple of times a year to ensure it remains obstruction free.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not becoe clogged.
If you have any questions, pleae let me know. I hope you find this information helpful.
Aug 19, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer gets hot and drum is turning clothes are not drying. cleaned lint tray and removed tubing venting outside and the dryer is making a whining noise. the dryer is only 14 months old
If the drum is turning and the dryer is getting hot, then this is good news, as it means that the dryer is mechanically sound.
First check to see if the internal workings of the dryer are not blocked by running the dryer with the vent tube detached. If there is lots of warm moist air coming out the hole in the back of the dryer where the tube should be, then your dryer is fine.
Next, if you've checked the tube that connects the dryer to the wall or floor and it is clear, then on to step 3.
Probably you have a blocked or severely restricted vent tube from the wall or floor to the outside. Over time, these always become clogged with wet lint that builds up into a crust on the walls of the tubing.
Find the exhaust exit on the outside of the house and run a sewer snake up into it to see if you can open a hole in the blockage. If that works to help the air flow, then you need to replace the tubing from your laundry room to the outside, as it is probably a solid crust of lint that has built up over years.
Again, the good news here is that your expensive new dryer is probably fine.
Jun 10, 2009 | GE Dryers
Whirlpool GGQ8831L Gas Dryer Logo
170 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
