Question about Frigidaire GLTF2940ES Front Load Washer
E-10 My washer just cuts off and displays an E-10 on the display screen.
    President:
  • 1,294 Answers
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Posted on Jan 24, 2008
Windows 10 screen cut off top and bottom how do I expand my screen?
Use the minu button ?? on your screen to stretch the image ( a square with 4 arrows pointing at corners)
Oct 26, 2015 | Dell Desk Top Computer--and Lcd Monitor 17...
Italled windows 10 and now my screen is cut off on the top and the bottom. Help!
This is an easy task.press the minu button of your screen until you reach the option of stretching the screen ( a square with 4 arrows at corners).
You can also adjust the resolution by clicking display icon in control panel.
Oct 26, 2015 | Computers & Internet
Tecra m2-s730 has failed to display properly instea it cuts signals
cut means flicker screen , pls plug to external vga monitor and remove video driver.
Jan 31, 2014 | Toshiba Tecra M2 P-M 1.7Ghz, 512MB, 60GB,...
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Dell 10" mini netbook is unable to display the entire contents of a web page. The bottom part is cut off. I tried changing the resolution to 1024X768 but it keeps popping back to the default.
Simply change the screen resolution.
Steps
Right Click on your Desktop
Click Properties
Then go to the Display settings
Select a lower resolution
Your problem will be solved
Cheers
Sep 01, 2010 | Dell Inspirion Mini 10 Netbook
I have a Whirlpool cabrio washer that displays LF when I try to start a wash load. The water comes into the tub but it doesn't fill. After some time, maybe 10 minutes, the washer stops and displays LF....
Aha the old LF : Captain we have a problem. What is it Spock? Computers cannot confirm water is filling, water level does not change. Spock you did pay the water bill this month? What could it be Spock? Captain the inlet screens appear to have contaminants. Suggest you jettison them. If that does not solve it see test #2b7fe528.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 15, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Upgraded eMAC G4 to OS 10 and have display problem
You SHOULD be able to control the monitor adjustments in os 10. In the Displays section of the System Preferences, look for the "geometry" tab. Under this tab you should be able to control width and height so your display fills the entire screen.
If you still can't find it, try adjusting the resolution and refresh rates. Also use the "detect displays" button.
Jul 15, 2009 | Apple Computers & Internet
Washer takes forever to complete cycle
SOUNDS LIKE YOU ARE STILL PUTTING TO MUCH DETERGENT IN IT. TRY CUTTING IT BACK A LITTLE MORE!! MINE DID THE SAME THING, THE SUDS LITE LIT UP AND AFTER ABOUT 5-10 MINUTES IT RESOLVED ITSELF WHICH IT IS SUPPOSE TO DO. I CUT BACK AND HAVE HAD NO PROBLEM SINCE
Apr 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Creative MuVo Micro N200
you have a bad displayor the connector to the display is comming off.
May 27, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Frigidaire GLTF2940ES Front Load Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
