Question about Maytag EPIC MFW9700S Front Load Washer
High speed spin problem
Since purchasing my washing machine May 21, 2007 (10-months ago), it has had two major catastrophic failures—motor changed. When it goes into a high speed spin cycle it becomes very loud and then--bang! While this model is NOT part of a Maytag recall "Potential spinner malfunction may occur at maximum load capacity" is does resemble the MAH 9700 recall.
  • Anonymous Jun 04, 2008
    I am having a similar problem with my Maytag Neptune Front Load. When I choose either one of the 2 highest speeds, it will accelerate until there is a bang and then it will slow down and abort the cycle. Unfortunately, the warranty period is over.
  • Gary Davd
    Gary Davd May 11, 2010
    no that was a motor controller board issue i belive post your email here in the comments section and i will send you the service manual.
    Genius:
  • 1,073 Answers
Contact maytag at 1-800-688-9900 and ask whats going on and you need your machine fixed while it is under warranty, it is only covered for a year.
they may refer you to a whirlpool number but whirlpool now ownes matag so this is ok
Posted on Apr 11, 2008
Will not go into high spin
Fault in the high speed winding of the motor or the failure of the control/switching to the high speed. Check to see the absence of the voltage which can confirm either the motor or drive.
Please check this out.
Aug 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I HAVE F06 CODE KEEPING COMING UP ON THE LED DISPLAY AND THE MACINE JUST STOPS WITH **** STILL RUNNING
Okay if this is a duet washer it is a major problem recommend a professional on this problem but here is the error code definition:
F/06 = Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
* Check wire harness connections between the Drive Motor/Tachometer
and the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
Nov 30, 2009 | Whirlpool Washing Machines
I have a F25 code pop up and it will not spin
If this is the washer and not the dryer then error code:
F25 = DRIVE MOTOR TACHOMETER ERROR
This is a major error you can try some of the items listed below?
If the control is unable to properly detect motor speed, the machine
shuts down. If a failure occurs during high-speed spin, the door unlocks
after 3 minutes.
1. Verify the shipping system including shipping bolts, spacers and
cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor
Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashes F 06
f 06 can be a major diagnostics problem, here are the details,
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component, usually the CCU
Sep 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing code F-6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check the MCU
Replace failed component.
Apr 12, 2009 | Whirlpool GHW9300 Duet Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Repeated failure of the aluminum hub which carries the spin tub. It appears to be eaten away by water or detergent. Casting pockets are filled with what appaers to be dried detergent residue in spite of...
The major cause of drum support failure is the use of todays modern powders and detergents, also .
another major factor is washing at too low a temperature.
At low temp washes , some of the active ingredients do not function at low temps..You need to change your washing habits.
Always follow the instructions on the wash powder manufacturers products, and at least once amonth do what is called a maintenance wash,this is putting the washer on at a high temp, with powder in, but no clothes.
This helps to keep the inside components clean
Another factor is using biological and non biological powders,
Dec 08, 2008 | Washing Machines
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
No spin cycle
Get the plug off the wall, open up behind & check what it is. Maybe the belt is off...........Only severe cyclones are catastrophic........
Dec 04, 2007 | Frigidaire GLTR1670A Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
273 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
