Computers & Internet Logo
Posted on Dec 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have locked the numbers on my laptop and don't know how. What is the shortcut to unlock. My lap top does not have a ten key number pad so the number are on the letters.
Ray Smith
Level 2:
  • Expert 124 Answers
  • Posted on Dec 14, 2009
Ray Smith
Expert
Level 2:
Answers
124
Questions
0
Helped
38813
Points
383
You should have a NumLock key - it toggles between numbers and letters
  • Ray Smith Dec 15, 2009
    thank you for your negative vote - I was just trying to help. Be more specific about your problems in future and you might get more helpful responses!
    well -thank you very much for the negative vote - i was trying to help. Next time give a bit more information about your problrm rather than being so general - and also an idea about how computer literate you are. You might then get a more pertinent response!!
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
tip
Best secret codes sony ericsson
<span><b><span><span>1.</span> S</span>ony Ericsson Secret <a>Menu</a>:<span> <span>-&gt; * &lt;- &lt;- * &lt;- *</span></span> (-&gt; means <a>press</a> joystick, arrow keys or jogdial to the right and &lt;- means left.) You'll see phone model, software info, IMEI, <a>configuration</a> info, sim lock status, REAL time clock, total call time and text labels. You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests) </b></span><br /><br /><span><b>2. IMEI Number:<span> <span>*#06#</span></span> -For checking the International Mobile Equipment Identity.</b></span><br /><span></span><br /><span><b>3. Lockstatus: <span>&lt;- * * &lt;-</span> -SIM lock - Do not lock your phone if you don't know the <a>unlock</a> code. This is another good check before you buy any phone, especially <a>second</a> hand ones. If phone is SIM locked, you may not be able to switch to other GSM operators.</b></span><br /><br /><span></span><span><b>4. Shortcut to last dialed numbers: <span>0# </span></b></span><br /><span></span><br /><span><b>5. Shortcut to sim numbers: <span>On main menu type a number and press # </span></b></span><br /><br /><span><b>6. If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press &lt;0000&gt;. &lt;&gt; stands for right arrow button or joystick.</b></span>
on Jul 27, 2011 • Cell Phones
I hit one of the function keys and locked up the keyboard Do you know how to unlock it?
Press the shift key and while holding down the shift key hit the f6 key located above your row of number keys,if that doesnt do it then look for a key on the top row that has a picture of a pad lock.Hope this helps,let me know,Thanks.
I`m using a wireless keyboard because the one on my laptop works but it has trouble on the part that has numbers witch are the letters .
From you're description it sounds like the "numb lock" check my be on. (numbers lock). On most keyboards you turn it on when you want to use the numbers pad. Or it may also be some other key shortcut on that keyboard which switches it to a numbers pad.
1helpful
3answers
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
5helpful
Number keys on think pad lock using openoffice.org
On Thinkpads laptops the keys on the right hand side double up as the number keypad. To switch on the Number lock key pad on - press and hold the Shift key and press the NumLk/ScrLk key, it is above the F11 key, the Num lock LED will also light up. Press these keys again to turn off the Numer Lock.
7helpful
2answers
Ten key pad keys are turned on. How do i switch them off
Solution#1: Accidentally pressing Sft+Numlock key combination will activate & inactivates ten key pad. (You'll see light enabled in padlock symbol with a number in it [i.e.beside ALL CAPS symbol on your lap monitor]).
Use: "ShiftKey+NumLock" (NumbLock Key: 2nd panel from Top right on keyboard)
Ibm think pad
The IBM laptop has a key on the top row on the right side.It has two functions. One function is the scroll lock on the bottom of the key.The other function is the numbers lock which is at the top of the key.To unlock the right side of the keyboard when numbers are coming up instead of letters, hold down the shift key and the numbers lock key and that will unlock it.
Laptop key problem
Look at the top keys on the laptop. There are icons under the main key. One of them would be the num lock icon. You would be pressing the Fn key then that key to unlock it.
Please respond if you need further assistance
Key borad
hold down the alt key and then type 0169 using number pad if possible. Make sure num lock is off.
If that is not possible, then hold down the ctrl - alt then press c.
Hope that helps you !
Grand Canyon Tech
Grand Canyon Tech
