Question about Kenmore Elite 45986 Front Load Washer
Slow Spin Rate
Washer spins very slow
Ok " sounds like belts are slipping, readjust or replace belts
adjustment bolts on motor will tighten belts
Posted on Jan 22, 2008
Maytag washer is sometimes out of balance and clothes are sopping wet when spin cycle ends. Washer is balanced on the floor.
1ST thing put less clothes in washer each time
second ck to see that drain hose is not obstructed from draining out the chamber , ive seen fabric lint get stuck inside the drain valves and slow and eventually block them off
last thing to look at
temp defeat the lid lock switch and or watch it spin thru window , your looking for the speed it spins at (should be a blur !!) , if its slow and not steady in rate but instead sort of gets slow/fast/slow/fast this could be an indication that your tub drive system isn't working well , this depends on a large bit of things working properly , but could be as simple as a worn out drive belt too.
Feb 03, 2017 | Maytag Washing Machines
My washer is stuck in fast speed. Can't make it agitate in slow speed. Model # 110 26892690 .
I assume you mean spin.You should have a slow/half spin selection on your machine if not select a delicates or wool program this will give you a slow spin.
Feb 24, 2015 | Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Washer spins slow or doesn't spin at all
Hello, If your machine is spinning slow, this can be an indication that your gearcase (transmission) may be going bad. One way to tell is to look under your machine. If you see any oil puddles on the floor, your gearcase needs replaced. A new gearcase runs about $200 and that doesn't include the labor charges (add about another $150). Good luck.
Thanks
May 19, 2010 | Washing Machines
Washer spins but too slow
Clean out the drain pump. Sounds like water is pumping out too slow. This added weight is slowing down the spin.
If water is pumping out OK and you still have the same problem, replace the drive belt.
Apr 01, 2009 | GE Washing Machines
Kenmore washer spins slow or will not spin
taking that it will wash,,you have a bad transmission,,onthejob
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Slow spin
Top loaders have a belt and a clutch. The motor has two sets of windings, slow for wash and fast for spin. You need a service engineer to correctly diagnose and fix.
There are parts here, but you need to correctly diagnose the fault.
Kenmore Washer Parts Repair Parts Sears PartsDirect
Feb 20, 2018 | Kenmore 42182 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
100 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
