Question about Gateway AR-230 DVD Recorder
Will Not Format DVDs
My AR-230 quit formating DVDs but will sometimes format a DVD-RW disc. It still plays DVDs but can't record/burn to DVDs.
Any Ideas??? Thanks
  • bull97 Sep 02, 2008
    Have a Gateway AR-230 DVD burner and when I hit record it wont record. The invalid symbol comes up on the top corner. I even tried hitting the record button on the burner itself. I've tried a 4x dvd and a 8x dvd. Both wont work. Trying to burn a home video to dvd. Will a 8x dvd work on the burner? Is there any formatting needed before burning?
  • 4 Answers
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid Maxell brand. Usually any other cheep brand will work.
Posted on May 30, 2008
Deretret
Posted on Jan 21, 2008
I'm having problems formatting discs for Panasonic EZ47 DVD recorder. Keep getting "formatting unsuccessful" message.
Now here are the types of DVDs that you can record to DVD-RAM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Now the only types that you can format are DVD-RAM, DVD-RW, DVD+RW
So first make sure you are not trying to format the wrong type of DVD. If you are using the correct type then you might want to try a different brand. Sometimes certain brands of DVDs have problems with certain players. You can also try updating your player's firmware and see if that corrects the problem also.
Jan 01, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
It wont record on 16xdvd+r discs? what is the properdisc
  • Media Type that the unit will play CD , DVD , CD-R , SVCD , CD-RW , DVD+R , DVD-R , DVD+RW , DVD-RW , DVD-ROM , Video CD
  • Media Format PAL , NTSC
  • Recordable Media DVD+R , DVD+RW only.. It will not record on the more expensive and compatible DVD-R, DVD-RW.
  • I recommend burning at a slower speed such as 2.4X, 4X or at most 8X.
  • I had similar issues resulting in many "coasters" for drinks burning at a faster rate even with my computer. Although some disks are designed to burn at a faster rate, software and components sometimes cannot keep up resulting in wasted money and time.
  • It may also be the media (manufacturer of disks). No matter which DVR or Burner you may have certain hardware schemes do not like certain media. It is a trial and error process. Just make sure the store has a return policy for the disks if they don't work. I have never had a problem returning disks to Staples that did not work.
I hope this helps and good luck.
Oct 27, 2009 | Gateway AR-230 DVD Recorder
On my AR_230 I have been trying to record from
Your DVD player can only read certain formats. You will need to use a program like Nero to convert the stuff you download the videos that your DVD player can read. Nero has good documentation, so just take a look at that, and decide what format you want to go with.
Your player should say what it can play in the manual.
Sep 19, 2009 | Gateway AR-230 DVD Recorder
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Invalid disk
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid memorex brand. Usually any other cheep brand will work.
May 04, 2008 | Gateway AR-230 DVD Recorder
I can't see the dvds into any dvd player
Most DVD players can't play DVD-R or DVD-RW unless it's finalized (if you record to DVD+RW, it may work ok, but fewer DVD players work right with RW format discs).
Obviously, you need to ensure you are actually writing to the DVD (eg, will they play back on the camcorder). You should see if there's a menu for finalizing the DVDs, that might do it. There are occasionally problems with finalizing discs on some of these DVD camcorders... these discs may not be readable on any DVD player, but might still work in a PC.
The other problem is that some camcoders record in DVD-VR format, which is a special "easily edited" format for DVD camcorders only... regular DVD players don't usually support this (well, some new ones might... this is one of those "evolving standard" issues). You'll probably need a PC to read the disc, edit, convert to a conventional DVD, etc. if you're using this format.
Jan 02, 2008 | Samsung SC-DC164 DVD Camcorder
Gateway AR 230 DVD Recorder will no recognize any of my dvds
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's. Usually any cheep brand will work.
Dec 03, 2007 | Gateway AR-230 DVD Recorder
Blank DVD discs that used to be recognised are suddenly not able to be read
I've found that once a disk is formatted in certain formats with a pc it prevents the LG from reading it.  Format it again in the LG (if you can!) or use the pc to format it using the UDF1.5 setting in a pc (which sort of resets it so the LG can at least see it as an unused disc again).
All in all I have found my RH19991H really confusing as far as disk initialization and formatting and finalizing is concerned.  Sometimes you can select to finalize a +-rw dvd and sometimes not (the latter is the the case according to the manual) and sometimes I can select the format mode and sometimes not.  Sometimes the machine auto finalizes the dvd+-rw (the way it should be says the manual) and sometimes it does not and then I cannot use it in the pc.  I have also created some disks with DivX files and was able to play them in the LG and then using the same pc, same type of discs, same video editing software and same settings created other DivX files I could not play on the LG.  It seems the software on the machine needs some work...
Oct 14, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Gateway AR-230 DVD Recorder Logo
169 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
