Question about Grilling
Jenn air 32 in. 4 burner gas grill
I put a replacement propane tank on and the burner lights for about 2 seconds then goes out. It does the same when I try a different propane tank. I got the grill this summer. Is it the regulator?
  • 3 more comments
  • chahn Apr 15, 2008
    I have the same problem. I got a replacement tank from Lowe's, like I have many times before, but the grill will only stay lit for a couple of seconds and then goes out. Can only keep the side burner lit for a minute or two. Can not get the flame to come up higher.
  • theDCSguy May 16, 2008
    If I light one burner it seems OK. When I light two they both seem to be at 25%. Light the third and all three go out. I too suspect the regulator since I have three tanks and two are kept full while the one in the grill is in use. My grill is less than a year old. I use the grill all year round and this problem only started recently.
  • JOE BLOWs May 26, 2008
    I GOT A LP GRILL THAT WAS ATTACHED TO THE HOUSE. I WANT TO HOOK IT UP TO A 5 GALLON LP TANK. WHAT DO I NEED?
  • slew Jun 10, 2008
    My mom has Weber Baby Q. The flame is very low using a propane tank. Loves the grill, but how do we get the flame higher and hot? Replaced the hose, called the help number--no luck.
  • AdsBerger Nov 09, 2008
    We can light the burner easy but then after 5 seconds the saftey shut off kicks in and the flame goes out
Sounds like a problem with the regulator. Try turning on the burners 1st before opening up the propane valve. If that doesn't work unscrew the gas line from the propane tank with the tank valve open a little (burners off) then screw it back on.
Posted on Apr 09, 2009
  • 32 Answers
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Lights but does not heat up beyond 250degrees
If this is a propane grill, try replacing the regulator and hose going to the tank. When a regulator is failing, it allows gas to pass, but not enough to allow the grill to heat up properly. If this is an older grill. You can also check each burner for blocked gas ports. Just a few blocked ports in a burner can prevent the burner from lighting completely, or from moving from one side of the burner to the other.
Jul 03, 2011 | Jenn-Air Grilling
I have a jinnair model JA460N Gas Grill that currently runs on natural gas, I need to convert to propane. Is this possible and if so is there a conversion kit available?
Yes, I believe a kit is available. If you purchased this Jenn Air grill from Lowe's, it was manufactured by Nexgrill Industries. Not Jenn Air. In any event, Lowe's no longer sells the Jenn-Air line of grills. My very best advice is to contact Nexgrill Customer Service @ 800-913-8999. In addition to the burner orifice parts you'll have to have, you will also need a grill tank Hose/Regulator Assembly.
Hope this helps and Happy Grilling!
Mar 16, 2011 | Jenn-Air Grilling
Grill will not light
If there is no gas check the tank, If the tank is fine look at the regulator. It has to be flat, because of a valve inside. This is a safety device incase of tipover.
Apr 14, 2010 | Jenn-Air JLG7130A
Jenn Air grill burners only lite on one side
It could be a bad regulator but,highly unlikely . Check your air shutters at the end of the burner tubes and adust them properly.And if you have a OPD propane tank you maybe turning it on to quick causing the check valve inside the gas valve to open half way. Try opening the valve slowly.
Oct 31, 2009 | Grilling
I have a Jenn-Air grill with three burners. When I light the first two burners, they light fine, when I light the third burner, the flames on all three burners get real weak and the grill will not go...
Screwy new tank has safety feature: so...
remove the tank and clear the the lines.then reinstall the tank and crack open the vave just a hair. Retry. Seen it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2009 | Jenn-Air JLG7130A
JA580
IF THE GAS YOU CAN SMELL IT WHEN IT COMES OUT THE HOLES FOR THE BURNERS MIGTH BE CLOGED OR THE MANIFOLD DONT WORK ON THE GRILL
Oct 02, 2008 | Jenn-Air JLG7130A
Grilling Logo
845 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
