Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860T
My washing machine went through the wash cycle, then displays F8, it first started with F5 and my hubby found a screw in the pump, great he thought he had fixed it but now it goe's through the wash cycle attempts to spin and displays F8 can you olease help? thank you, Barbara
  • 2 more comments
  • nannamole Jan 21, 2008
    MMMMMMM I asked for advice on a Hotpoint WF860 Ultima washing machine not a STOVE. Please have another think. thank you Barbara
    Please can you help, I have a Hotpoint Ultima FW860T washing machine, it went through the wash cycle and stopped and flashed F5 my hubby found a screw in he pump and thought he had solved the problem, but now it go's through the wash cycle and flashes F8 can you help? Thank you
    How do I check the heater control NTC (thermistor)temperature sensor, and where in the washing machine is it located. The pump, filter and motor have all been checked. I have just tried the washing machine again and it gets to the rinse cycle, emptys the water fills with clean water,emptys, then tries to spin, flashes up end and then F8. I really appreciate your help and advice. thank you once again, Barbara
    No sorry I do not have a service manual, but my hubby is very machanical minded and if you explained things to him, he would be able to have a look
    Guru:
  • 1,894 Answers
Do you have any service manual??
Posted on Jan 21, 2008
  • dewan nafees ahmed Jan 21, 2008
    F08: Heater control or NTC (Thermistor) temperature sensor problem
    • Check the Water Temperature Sensor, Heating Element and Element Relay
    • Check connections to the Sensor, Heating Element and Relay
    • If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F08" error code will be displayed.
    • Check:
      · venting for restriction
      · thermistor
      · control board
      · cycling thermostat (regular)
    • Ambient (room) temperature too cool, -or-
      · thermistor
      · wire harness
      · control board
    • · Check heating element
      · Check thermostat
    I DINT GET ANY SERVICE MANUAL FOR YOUR PRODUCT.. ITS YOU WHO CAN LOOK AT IT MANUALLY AND DO CHECK OUT WHERE THERMISTOR IS LOCATED.. ITS TOUGH JOB FOR A PERSON WITH MECHANICAL KNOWLEDGE TO FIND THE THERMISTOR LOCATION.. YOUR HUBBY CAN DO IT SURELY I THINK
  • 8,617 Answers
Here is the breakdown of Hotpoint awsher codes.
HOTPOINT/CREDA fault codes:
E10: No cold fill - check that the cold inlet tap is not turned off, or the inlet pipe is not kinked.
E11: No hot fill - check tap and hose as above.
E12: No MIXED fill - same checks as above, or possibly the inlet valve is faulty
E13: water inlet fault, or filling too slowly, similar checks to above.
E14: water not heating - check heater element or THERMISTOR (NTC).
E15: Water not pumping out, or pumping out too slowly. Check pump for obstruction or foreign objects jamming pump, or kinked drain hose, or blocked outlet/U-BEND.
E16: Very high water level - turn off water supply, and have inlet valve checked or replaced, or water level sensor checked/replaced.
E17: Door not closing properly, or door interlock faulty.
E20/21: THERMISTOR resistance drifted out of range (faulty), or ambient temperature below freezing.
E30/31: Motor problem - check motor brushes, drive belt, tachometer or tachometer magnet, motor relay or PCB (TRIAC motor control).
E40: Water level too low during heating cycle - check supply or inlet valve, or float level sensor. Check water pressure is high enough to fill within time limits of logic checks.
E41: Water level detect sequence error - check items above for E40, plus jammed pump.
E50/51: Model specific language and programmer codes have not been loaded/saved in programmer memory correctly. The machine will run on programmer common defaults (1000rpm spin and English). Book an engineer to reprogram the unit.
F01: Aquarius and Ultima models may show this. It could be a faulty motor or motor control board. The motor tachometer could also be faulty. Some machines have a little rotating magnet and sensor, and the magnet can become detached (not sure about these though on this model).
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
F07: Heater control or heater relay, or heater element problem.
F08: Heater control or NTC (Thermistor) temperature sensor problem.
F11: Pump related. Pump not able to empty water correctly. More blockages to check for: something inside the pump stopping it or reducing it speed. Sump hose blocked between the outer drum and the pump. Outlet hose blocked between the machine and the U-BEND. The pump could also be weak, pumping too slowly, or intermittent.
  • Sonny Berry
    Sonny Berry Jan 21, 2008
    I have done some checking the NTC thermistor is a zero resistance resistor that increases as temperature goes up. I have been unable to locate any information as to the availability to purchase just the thermistor. Every place I have checked said you will have to contact hotpoint for a replacement circuit. I am also informed that the parts have a 5 year warranty for free replacement . You may need to contact hotpoint to check into this option. Sorry I couldnt help you more but hotpoint doesnt have much info available.
  • 796 Answers
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
  • isaac johny
    isaac johny Jan 21, 2008
    How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
  • isaac johny
    HOTPOINT
    Range/Stove/Oven Fault Codes
    Failure
    Code
    Condition
    Check/Repair
    F0 and F1
    Failed Thermistor Control
    Replace Electronic Range Control (ERC)
    F2
    Oven temp exceeds 590 w/ unlocked door
    High resistance or interference in oven temperature sensor, replace sensor
    F3
    Open oven temperature sensor circuit
    Replace oven temperature sensor or, check for an open oven temperature sensor fuse, replace fuse.
    F4
    Shorted wire (oven temperature sensor)
    Locate and correct
    F7
    A = Function pad button stuck or
    B = Bad clock
    Unstick button or replace Electronic Range Control (ERC) clock assembly
    F8
    Component Failure
    F9
    Program w/ door circuit
    Check wiring
Why doesnt the fabric conditioner dispenser empty after each wash?
The softener dispenser is flushed with water as part of the wash cycle. The residual water prevents softener from clogging the dispenser between was cycles.
Aug 01, 2014 | Hotpoint Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Test Error
Hold In on/off and start buttons together for 10 secs.
Feb 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Not spinning- F5 fault error Hotpoint Ultima
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
May 11, 2008 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima plus washing machine door wont open after wash
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
Apr 14, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
806 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
