Question about Kenmore Oasis HE 27082 Top Load Washer
Ld error message
I get a Ld error message, is anyone familiar with this message? I have a cycle that stopped in the middle (won't finish the cycle)
  • 1 more comment
  • washerstuck Feb 09, 2008
    I am having the same problem. The display shows Ld. I tried opening the back panel, but was unable to take the drain pipe out to check if it is clogged....Can someone give me detailed instructions on how to unclog the drain pipe...Thanks
  • mothrof4 Mar 19, 2008
    I have the same problem. I will put in a load of wash and almost every time the machine will start beeping at some point during the cycle and display ld. I run back down and press stop and start, but then a few minutes later it is beeping again. It might happen 3 times for one load. Once in a while a load washes with no beeping. We have had this problem since we got the washer, so I figured there was nothing wrong with it was overly-sensitive. Now I am wondering if there is something wrong. It can be very frustrating as we have four children and often are doing laundry late at night after work.
  • robin Aug 15, 2013
    youmay want to check the drain system hoses, sometimes small things get through to the pump and clog th pump propeller where won't drain well or sometimes not at all.hope this helps.
  • 125 Answers
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Posted on Jan 21, 2008
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
Won't finish a wash - LD is displayed. took everything out & tried to do a cycle so that the water will drain & it still says LD. Purchased in 2002 and this is the same problem that happens...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Washing Machines
My washer shows an "ld" code after stopping in the
I have looked and looked and can't find an error code "ID" for any Maytag washing machine! Are you sure that is what is being displayed.
Jun 05, 2011 | Maytag Washing Machines
My washer stops in the middle of the cycle what does this mean Flashes LD Error
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer does not finish the drain cycle and it shows a LD error and does not finish washing.
LD error is for long drain. The pump filter in the pump assembly is probably clogged. Remove front lower panel, pump assembly is in the front with a cap that unscrews. Once cap is unscrewed you can slide out the filter and clean. Remove as much water as possible from basket before taking off pump cap or else water will come flooding out when filter is removed. Reinstall and run drain spin cycle. Should drain ok.
Feb 02, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Stopped - no error message, power, drainage lines all good Andy
No Power on when the power button pressed.
Check out the web site
http://spares.bigwarehouse.com.au/file.php?document_id=5831
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Kenmore Oasis HE 27082 Top Load Washer Logo
285 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
