Question about Kenwood KAC-X201T Car Audio Amplifier
Kenwood KAC-PS201T hi, ihave a kenwood KAC-PS201T and i can get it to power up? is there anywhere i can get help!
  • Anonymous May 07, 2008
    MANUAL DE INSTRUCIONES
  • Anonymous May 29, 2008
    help!
  • 631 Answers
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
No plug for kenwood amp kac-920
these people are idiots i am having the same problem with my 1020 i cant find one anywhere i am about to just go to radio shack and buy the clips and some wire and just by-pass it i have been looking for a couple years now and even my friend that works at a car audio place can not find me one
Feb 06, 2012 | Kenwood Car Audio & Video
I dont no how many watt my amp has
Hi and welcome to FixYa,
To my understanding, a Kenwood KAC-628 is rated with max power of 100 watts X 2 at 4 ohms per channel. Incidentally, it is bridgeable resulting to 300watts X 1.
Good luck and thank you for asking FixYa.
Dec 23, 2009 | Kenwood Car Audio & Video
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Power lite on, no sound from amp after 1hr of usage
HI DUDE UR REMOTE WIRE FUSE IS BURNT .... REPLACE IT ... AND UR SPEAKER ... OR SUB TAKES LOT POWER FROM AMP .... ....
Apr 17, 2009 | Kenwood KAC-428S Car Audio Amplifier
LOW VOLTAGE
start with a voltage meter see if you have 12 v
check your ground
check all your connections ... "most the time i will simply rewire the whole sound system"
hope this helps
Dec 26, 2008 | Kenwood KAC-X201T Car Audio Amplifier
Kac-ps201t problem
I had a similar problem with a KAC-X812D Kenwood amplifier.
My problem turned out to be that the RCA inputs were so sensitive, they picked up interference from my head unit through the RCAs.
I replaced the head unit with a newer model, and had no problems after.
This may not be your case, but hope it helps.
Dec 15, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amplifier problem
There is a mono/stereo switch on that amplifier. Make sure Stereo is selected.
Dec 15, 2008 | Car Audio & Video
Amp not working
do u need the remote wire hooked up to your cd player for your amp to turn on
Nov 12, 2008 | Car Audio & Video
Kenwood KAC-X201T Car Audio Amplifier Logo
754 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
