Question about Oasis Hunter 54' Ceiling Fan
Quit We have a Hunter fan/light that is about 4 years old. Yesterday the light went out - we changed bulbs - nothing. The remote light indicates it is working but neither the light or fan will come on with the remote or wall switch. Is there a fuse or breaker? This was in the house when we bought it a year ago, so we do not have any information/directions.
  • 397 Answers
If you get in touch with hunter they will send you a replacement reciever for you unit if its not discontinued
Posted on Jan 21, 2008
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
My Hunter fan with light kit has a problem, again. The remote control works for the fan but not for the lights. One bulb burned out. Then the remote stopped working. Replacing the burnt out bulb did not...
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Aug 04, 2011 | Hunter Ceiling Fan Remote Receiver...
I have a hunter ceiling fan and the light blew, when it blew then the remote quit working for the light, it still turns the fan on & off but after I replaced the bulb it still will not operate the...
Hello nita... I believe the fact that the remote stopped working is due to a weak battery in the remote. Change that battery and you should be back up and running. Joe
Thanks for choosing Fixya!
Jan 14, 2011 | Hunter 20537 / 20538 The Vista Iron...
Fan and light suddenly wont work.
May be the receiver Call Hampton Bay @ 18005533199 have your UPC number ready
Oct 27, 2009 | Hunter Dryers
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Jul 01, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
No power to hunter ceiling fan or light.
It sounds like either the top part of your remote is bad, or you have a bad connection to it. Have someone that is familiar with electricity (that may be you?) check to see if there is power to the ceiling box, and fan's remote that is ususally in the ceiling box, or just under it in the cover. If you have power there, your remote is failing.
Nov 23, 2008 | Hunter 52" Ceiling Fan With Light And...
Oasis Hunter 54' Ceiling Fan Logo
305 people viewed this question
Top Oasis Dryers Experts
Marvin
Marvin
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
