Question about HP DeskJet 3325 InkJet Printer
NOT PRINT PRINTER CONTINOUSLY BLINKING WHEN COMPUTER ON AND NOT PRINT WHILE BOTH CARTAGES ARE FILLED
  • PeteVfi Jan 23, 2008
    Hi!
    I do have about the same problem, but the carriage do not move at all from any position, but the belt is moving according to some short procedure when powered on, also repeteadly several times. I checked the belt is loose from the carriage, probably the plastic belt holder on the carriage is broken and away, so, maybe not worth to repair anymore even a spare carriage would be found somewhere ...
    Best regards,
    Pete V.
  • PeteVfi May 11, 2010
    How about the long plastic strip guiding somehow the carriage, I noted it was very dirty and black, should it be all clear or having some light markings on it?
I seem to be having the same problem and the computer engineer said that the circuit has gone. I don't know whether the circuit should be changed, because it is working out quite expensive. And I just changed the cartridge! Could it be anything else?
Posted on Mar 09, 2008
Installed ink cartages. where the ink cartages go it makes a loud clunking noise. then it comes up as an error for the the paper and the ink. tried pulling the cartages out and replacing them in again and...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
Have second hand lexmark e260dn and status light
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Jul 16, 2010 | Lexmark E260dn Laser Printer
Green light working continously
It might be you change your cartridge to that and you did not insert it properly so that they blink. Try to check the cartridge if it can insert properly then restart your printer and try to print it again. If they are blinking again just press the reset button or turned off your printer then turned it on again and try to print.
May 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
How to refill hp564 ink cartages?
Please, do not wast your time doing that. Re-filled cartridges can cause a myriad of print quality issues. They also may be grounds for the printer manufacturer to void any remaining warranty that may be left on the printer.
I know that these vendors will the ink is fine but nine times out of ten the chemical signatures of the ink will be different.
Protect your printer and use the ink sold by the manufacture. Its not worth throwing out the printer because the ink damaged the print head or does not flow properly.
Don
Jan 22, 2010 | HP Photosmart Premium C309A All-In-One...
Printer keeps asking to hit enter to align print cartages. When I hit enter it cant finish the alignment and tells me it failed but not what is wrong or what to fix.
Printer keeps asking to hit enter to align print cartages. When I hit enter it cant finish the alignment and tells me it failed but not what is wrong or what to fix. Me Too!!! what is the answer
Dec 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't Fill ink in X2650 Lexmark
If your looking for cheap ink, try buying a more expensive printer as ink for the expensive printers are relatively cheaper. I also tried refilling the inks for my printer but to no avail, it simply leaked out the bottom making a big mess
Jun 08, 2009 | Lexmark X2650 All-In-One InkJet Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
HP DeskJet 3325 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
