Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock is onHow do I get it off? - Whirlpool Duet GHW9150P Front Load Washer
  • 125 Answers
The button on the far left should have a little padlock by it, if not look for a button with the small padlock, press and hold it until the control lock light shuts off. You should only have to hold it in approximatly 3 seconds.
Posted on Jan 21, 2008
    President:
  • 1,294 Answers
Find the lock button & hold it down till the light goes off. Look for it carefully.
Posted on Mar 16, 2008
Thank you! It worked! :o)
Posted on Mar 23, 2008
My 2009 Pontiac G5 started doing this about 3 months ago. On startup, the door locks make noise and it takes a while to shift out of park
Have the vehicle checked for DTC'S diagnostic trouble codes stored in the BCM - body control module . Everything is electroniclly controlled .
Automatic Transmission Shift Lock Control Description and Operation
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock solenoid (serviced as the automatic transmission shift lock actuator), as well as the body control module (BCM) and the engine control module (ECM). The shift lock solenoid is located within the floor shift control assembly with vehicles equipped with floor shift.
• The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will remove voltage from the shift lock solenoid:
- The ignition is in the ON position.
- The engine control module (ECM) sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
- The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically locking the shift lever in the PARK position as the solenoid energizes. When the brake pedal is applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid releases the mechanical lock allowing the driver to move the shift lever out of the PARK position. When the transmission is out of the PARK position, the shift lock control solenoid remains de-energized.
During remote start operation, the BCM will energize the shift lock control circuit, locking the shift lever in the PARK position.
The BCM supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position, the reference voltage is taken directly to ground and the BCM senses 0.0 volts on the signal circuit. If a door lock switch is placed in the unlock position, the reference voltage is taken to ground through a 15k ohm resister that is internal to the door lock switches and senses approximately 2.9 volts on the signal circuit. This is how the BCM determines what portion of the door lock switch was activated.
Aug 22, 2017 | Pontiac Cars & Trucks
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
2005 Buick Rendezvous you can hear the relay clicking but the door locks will not open and close
Check for broke wires inside the boot from body to driver door , this is a common problem . If you don't find broke wire's , pull the door panel to get at driver door switch . Check for voltage an ground circuit .
Rendezvous Door Lock System Components
The power door lock system consists of the following components:
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Oct 12, 2016 | 2005 Buick Rendezvous
2005 Chevy Impala. The door locks keep locking during drive.
It's probably a bad input to the BCM - body control module ! Have it checked for DTC'S - diagnostic trouble codes .
The automatic door lock function can only be enabled by the body control module (BCM) if the driver door open switch and door ajar switches are in the Closed state. For information on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
DTC B3064 or B3069
DTC B3127
DTC B3128, B3133, or B3138
DTC B3132
DTC B3137
DTC B3272
Your best bet , take it to the chevy dealer . Unless you own a GM factory Tech 2 scan tool an have access to factory sevice repair info.
The outputs to the door lock actuators are controlled by the body control module (BCM). When the BCM receives a lock input from a door lock switch, or a keyless entry transmitter, it applies battery positive voltage to the door lock actuator lock control circuit, a ground to the door lock actuator unlock control, and the driver door lock actuator unlock control circuits. When the BCM receives an unlock input from a door lock switch, it applies battery positive voltage to the door lock actuator unlock control, the driver door lock actuator unlock control circuits, and a ground to the door lock actuator lock control circuit . When the BCM receives an single Unlock input from a keyless entry transmitter, it applies battery positive voltage to the driver door lock actuator unlock control circuit and a ground to the door lock actuator lock control circuit to unlock the driver door. A second Unlock input from the transmitter applies battery positive voltage to the door lock actuator unlock control circuit, and a ground to the door lock actuator lock control circuit to unlock the passenger doors.
This diagnostic procedure supports the following DTCs:
• DTC B3128 Left Front/Driver Door Unlock Circuit High
• DTC B3133 All Door Unlock Circuit High
• DTC B3138 All Door Lock Circuit High
Jul 21, 2017 | Cars & Trucks
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
The controls locked is displayed. what causes this and how do i get the controls unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Kitchenaid superba stove
Control Lock
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Hooking up to Wii
Hi you have not mentioned your internet service provider ,,
However ,you can click on the link below to get basic information onhow to configure Wireless connection on the router.
http://register.wireless.utoronto.ca/?page=linksys
If the default user name or password provided in the link doesn't work then you will have to reset the linksys router to the FACTORY DEFAULT by pressing small "reset" button at the bottom of router all lights should go off briefly when you reset it.
After reset you can follow the steps given in the link.
Cheers
May 31, 2008 | Linksys Wireless-G WRT54G Router
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal De
