Question about Dayton E52 Utility Heater
Dayton e51 kerosene heater
Very strange, the machine comes on with the fan , spark and fuel.It lights briefly and then cuts off.The led flashes on the side.Now if you take the top cowling off, it will operate properly.
We have a 3VE53C 400,000 btu heater , the fans will come on you can hear the ignitor and fuel will run out of the front of the unit. It trys to fire twice and will not. Then you get the E1 error sign.
Posted on Dec 01, 2008
  • 90 Answers
One other thing to look at is the photo sensor. it has two wires and faces the front. it will have a rubber housing and if you pull it out of its holder you should look in the end. if all you see is soot take a soft rag and pencil and try wiping it off. be careful not to use too much pressure as it can be damaged. either it or the small opening it looks through is plugged. it has to see a flame or it assumes that it did not light and will shut off the unit. this may go in a cycle over and over.
Posted on Jan 26, 2008
On our 110,000 btu dayton heater. when plugged in the ignitor immediatly turns red then immediatly turns off. What's the problem?
Posted on Feb 11, 2010
Can you use diesel in a kerosene forced air heater ? jim
Posted on Jan 07, 2009
  • 4 Answers
Thermostat is touching hot metal when cowling on, there is a emergengy shut off sensor being activated while cowling attached---thermostats are meant to be placed with some space around them--they are calibrated thusly, if this space does not exist or if has lost its mechanical integrity- then any unit using such a device sops working properly
Posted on Jan 21, 2008
Nail gun will not fire green light on gas ok after drop on congrete floor
A quick diagnostic check. First remove gas cell press nose against solid surface to dispose of any gas that may be in chamber.
1. Insert battery - LED should flash.
2. Press nose against solid surface - LED should be lit permanently (if still flashing possible fault moulded circuit board or fan motor micro switch lever, if flashing red green high possibility motor fault). Listen to hear fan running if not heard fan blade may have fallen off motor.
3. While still pressed against solid surface press trigger and watch LED - LED should blink off then light again (may flash red on guns newer than 2006) If does not blink fault either Spark unit (controller) or moulded circuit board trigger micro switch. To test for LED blink again release pressure on nose then press again. The blink indicates that a spark has been sent to the spark plug.
4. If 1 to 3 are OK problem most likely gas related or leak in seals. Ensure driver blade not still forward a possible fault of sticking forward after being dropped is nose slightly bent this traps the driver blade when first fired and does not return. (jammed nail gives a similar fault.) If nose is the fault it will require a new sleeve.
The moulded circuit board is normally cheapest then spark unit and sleeve roughly about same price the motor is most expensive.
Hope this has been some help to you.
Jan 13, 2015 | RTO PasLode 900420 Impulse Framing Nailer
Turn on optoma 605 R light flashes but wont stay on fan is running fine.
The problem is: Bulbs wear out. Especially projector bulbs. The operate at high temperature and the filaments break down in time. When they are intermittent (on/off) the filament expands and contracts, and at some point disconnect entirely. It is time to replace the lamp with a new one.
Feb 05, 2018 | Sharp XR-11XC DLP Projector
I HAVE A 1998 VW CABRIO with left blinker issues
Ok I fixed her light issue after investigating strange noises under the hood. The wiring harness mount holding clip between the frame and radiator fans at the hood latch broke and the wiring was rubbing against the fan, cutting 3 wires and exposing 4 others. electrical taped frays and made jumpers for the cut ones and WHALLAH! All good. The reason it evaded so long is it was about out of plain sight because of the shroud until it broke the main holding clip and dropped the cluster of wires and the big connector down it wasnt loud.
Nov 22, 2012 | 1998 Volkswagen Cabrio
Ruff idol, poor acceleration. EGR light on. Idol was ruff for several days. Replaced distributor,coil,spark plugs,spark plug wires,air filter and fuel filter. EGR light did not come on until after the...
Cycle your key on (not start) then off, on, off, then on and leave it on. Now count the flashes from the "check engine light" and get back to us with those codes. It will flash a 2 digit number, but pause briefly between numbers. For example: 3 flashes,pause, then 3 more flashes is code 33. 1 flash, pause , then 5 more would be code 15. When you get 5 flashes, pause, then 5 more, that's code 55 and it just means end of message or codes. You'll also get a short pause between codes as well, so have a pad and paper ready and keep your eyes on the check engine light.
Jun 29, 2011 | 1987 Dodge Dakota
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
HP Pavilion dv6225us won't boot (power not the issue)
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
Jun 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Dayton E52 Utility Heater Logo
1,581 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
