Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Wep210 how do i charge it ?
  • 3 Answers
There's a small power jack under a tab at the base of the unit. I found it only charges if you plug it into the transformer travel charger. For some reason plugging it in the PC USB port doesnt work.
If the unit is being charged a red LED will light up, turns blue after 2/3 hours when its fully powered up.
Posted on Jan 23, 2008
I m unable to pair my wep210 headset with my samsung omnia i900 mobile
the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
Jan 28, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG MOBILE CANT LOCATE THIS HANDSET
I have bluetooth samsung 210 and I just bought it todaty , ,my mobile does nit see it
Jan 06, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
How do i change the earpiece on my samsung wep210?
YOu charge it with a samsung phone charger - and a small grey double ended attachment that should have come with it - this plugs into the bottom of the earpiece after pulling back the flap, and the phone charger bit goes into the other end. Alternativeley - there are lots of sites selling in-car chargers for these.
Jul 17, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG BLUETOOTH WEP210 NEED TO KNOW HOW TO PAIR TO PHONE
Your manual can be found here... it should walk you through the connection process fairly easily.
Mar 23, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Bluetooth code
Usually with headsets code 0000 works by default.
Aug 05, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Jun 05, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Charging
Jan 08, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung bluetooth wep-210
After charging hold the front button under the samsung name down until the blue light flashes.
caster44
Jan 04, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
103 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
JP Services
JP Services
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
