Question about Philips GOGEAR SA6045 MP3 Player
Sync it is frozen on the pc but says to disconcect from device
  • Anonymous Feb 04, 2008
    my player wont turn on at all
  • 8,596 Answers
Did you run the installation CD that came with the GoGear? (if you have Windows XP)
Grab the installation software from the Philips website (if you have Windows Vista)
If this was done, then:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the firmware upgrade by clicking on the update tab in Philips Device Manager. The firmware upgrade should resolve the issue permanently.
-Tha Mp3 Doctor
Posted on Feb 04, 2008
Acer laptop cursor frozen
Your mouse function is not working, you can try external USB mouse,
probably the mouse pad is off, check in device manager from system properties in control panel, if it shows mouse installed.
Dec 16, 2013 | Acer Computers & Internet
Still frozen
Press and hold [VOL+] & [POWER] until the player resets.
If the player restarts normally then all is well.
If not, reset again and connect the device to the PC.
Install and run the Device Manager software from the product CD.
Select Repair / Restore option and follow the on-screen prompts.
Goodluck..
Feb 29, 2008 | Philips GoGear HDD6330 MP3 Player
Sound volume frozen on acer
That is a software issue, do a system restore of the computer bringing it back in time before this happened.
Apr 11, 2012 | Acer Aspire 6920 Notebook PC
From ignition sometimes abs will come then go out while driving, I changed the ignition switch but no change still comes and goes.
change rotors and brakes and then disconcect your battery for a min. or two. if you still have the problem then you may have a short in your abs system not ignition
Mar 21, 2012 | 1988 Lincoln Mark VII
My screen is frozen and my PC doesn't recognize the mp3 player anymore
Go into your device manager, and under USB look for your device. If it is there, then delete it. If this still doesn't work then there could be a physical issue.
Jan 11, 2018 | Emerson MP530 MP3 Player
The engine cooling fan will not stop. Battery was dead yesterday, needed new one, put it in, then fan started and would not stop (for hours)had to disconcect the battery. What is wrong?
  1. locate the engine cooling fan relay/disconnect/does fan stop
  2. if so reconnect relay
  3. locate fan switch in radiator or intake manifold
  4. disconnect switch/does fan stop?
  5. if so replace switch
  6. if not replace relay
  7. this solution does not check for electrical wiring problems
  8. such as opens or shorts to ground
Jul 27, 2010 | 1994 Honda Accord
The mouse or arrow of my pc stops and i have to restart my pc again.
Confirm if your PC is frozen, or if the mouse has stopped working by pressing the WINDOWS key on your keyboard. If the mouse has frozen, pressing the windows key will bring up the start menu. If it does not open, then the Operating system is frozen. Try opening your DVD / CD-ROM device. When it opens, the PC is not frozen.
If the Operating system is frozen, then most likely you have a Hard Drive problem, extreme Hard Drive fragmentation or corrupt system files causing this.
May 30, 2010 | Acer Computers & Internet
Frozen screen
The player can be reset if frozen by pressing and holding POWER ON & VOL+.
If the problem persists the only way to fix it is with Philips Device Manager. There is no Linux version available though.
Perhaps you can hijack a friends Windows PC to run it.
Apr 11, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
79 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
