Question about D-Link DIR-625 (790069292637) Wireless Router
No connection with Inter with dir-625 - connection Poep
I try all of the solutions wrote here for the others. But when i go to WAN , click on connect and nothing happen. It even try to connect and reconnect by itself , but still dead no connect. I'm with Bell system. Sympatico.
Any solution for that. Thanks
  • dragon51 Jan 30, 2008
    Thanks for your interest. my service are dynamic ip . modem from bell sympatico services is a speedstream . Let me know if any solutions.
  • irlapati May 11, 2010
    What kind off internet service do you have?
    Novelist:
  • 173 Answers
If a single computer is connected directly to the speedstream modem(a model number would be an added help), do you need to sign on with your userID and password that was provided to you by Bell Sympatico? if the answer is a yes you may need to setup PPPoE on your router but if your answer is no, then you may need to check the IP address your computer is getting from the modem if it's a private IP(192.168.x.x or 10.10.x.x) that means your speedstream modem is set to PPPoE, check if your router has the similar IP address as your modem, compare the default gateway address your computer is getting when connected directly to the modem and when connected to the router if they have the same segment like 192.168.1.x or 10.0.0.x your required to change the IP address on one of the device, my suggestion is to change it on the router then make sure you connection type is set to obtain IP address automatically(DHCP) or something like that and check if your router will get an IP from the speedstream modem.
Posted on May 12, 2008
How do you hook up a dlink router to a telus modem, the WLAN connection won't work.
Newer telus modems tend to be wireless.
If your telus modem is wireless, then you want to forget the DIR-625 all together and simply connect your computers to the telus modem.
If you have a standard telus modem, you will want to connect a LAN cable from the modem to the WAN port on the router and then connect your devices to the router.
Please come back and vote or leave some feedback, it will let me know whether it helped so I can improve and it will encourage me to keep on helping.
Thanks,
Pat
Mar 31, 2010 | D-Link DIR-625 (790069292637) Wireless...
Wireless network will not work
Try to reset the router, but press the button for about 20-30 seconds. Connect it to the computer, make the wan settings, enable the wireless mode, make the settings for the wlan network(you could encrypt your network, or filter the ips you want to connect to your network)
Feb 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
No connection to DIR-625
Make sure the modem is connect to your router under the WAN
Access the configuration page of your router. using the address bar.
type in 192.168.0.1
Username : admin and leave password blank
Under WAN choose dynamic and click on clone mac address.
Click on Apply then click on continue.
Go to Status if you have IP address it means you can connect to the Internet.
Mar 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
Error code 109 D-Link Router DIR 109
can you connect to the router interface? what does it say the wan status is?
Mar 09, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link connect to comcast
connect the the ethernet cable to the WAN port of the modem.
the connection should be:
One end of the cable is connected to the modem and the other should be connected at the WAN port of the modem.
Now use another Ethernet cable plug it in on the LAN port1 and the other end to your computer.
Access the configuration page of your router and set the wireless setting inside your DI-624 router.
Dec 10, 2008 | D-Link DIR-625 (790069292637) Wireless...
DIR-625 Blocking DWL-G510 connection
1) First you need to check if the router is blocking mac address. Login to the DIR-625 by typing 192.168.0.1 on the address bar of IE.
Use admin for username and leave password blank or type in your password.
Go to Advance Tap, on the left click on Network Filter. Select Turn Off Mac filtering, click on save settings. wait for your to reboot. If that doesn work try option tow below.
2) What you need to do is Upgrade to the latest firmware on your router (Resolves 99% of all problems). Make sure you download the right firmware for there are two version of the DIR-625 ( Rev. A & Rev. C).
You'll also need to make sure you have the latest driver for the adapter since you have a newer computer.
Sep 22, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cannot connect
The vista is wireless?
Right click the computer icon on the bottom right hand>click connect to a network>then click network and hit connect if its secure it will ask you for the security if not just click connect anyway.
May 09, 2008 | D-Link DIR-625 (790069292637) Wireless...
Can't figure this D-link out
does it have encrypion set up on it? if so, are you putting in the correct security key?
also, are you sure you're trying to connect to YOUR wireless network. you may be trying to connect to another network nearby?
Tony
Mar 03, 2008 | D-Link DIR-625 (790069292637) Wireless...
No connection wirh internet with DLINK dir-625 ?
does your isp provide dynamic IP??? or does it need a static IP??? ask you ISP provider about it...
Jan 22, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
252 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
