Question about HP Pavilion a1000n (PS567AA) PC Desktop
No sound I have no sound. tried everything except BIOs
  • 5 more comments
  • gbarch Jan 21, 2008
    everything is greyed out. I cannot ajdust anything
    I didn't rate anybody. I hit the Accept button by mistake.
    I think I need to go to Bios and turn the audio system on or somethign. Except, I don't how to do this. I am not very computer savy.Thanks
    I tried Kazong's soulution. But everything is greyed out, I cannot adjust the volume. What do I do?
    Mr. Sweet Rascal, pl.tell me how to check the audio driver setting. Looks like it is not enabled. Thanks
    Mr. Sweet Rascal, I did not install any other audio drivers. All I have is what came with the PC. When I go to Sound and Audio devices from the control panel it says " no sound device" and everything is greyed out. When I check under driver it says: all drivers are working properyl.
    Mr.Sweet Rascal, I don't know if my system has in built sound card or not? how do I find out?
  • 4,102 Answers
Hi the problem your having is either a software problem or you sound card is failing and needs repalcing but first try this
1 start
2 controll panel
3 hardware devices
4 let comp search for devices
5 scroll down list untill you see your sound card
6 select this
7if you have disk insert if not tell comp dont have disk
8 let comp search net for the correct software and install
if still no sound then you will find your sound card no good and will need replacing
Make sure volume turned up
Also if you right click on the speaker in bottom right hand corner then select speaker properties check all setting then this should solve your problem let me know how you get on or if you need further assistance ok
Posted on Jan 21, 2008
  • paul proctor Jan 21, 2008
    why rate fixya solution for sweet rascal as you be charged for this even though problem not solved.
    Any way if everything greyed out then you need to reinstall the software as this is corrupt try going to makers website and their you should find the downloadable software for your device
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Try opening your control panel .click on systems, device manager
look at your sounds try updateing your drivers ..if you have on board sound/video(((((((( if you have a sound card try re-seating it -- also look in the control panel click on sounds or the speaker icon and make sure your volume is up and nothing is muted.. hope this helps
    Guru:
  • 1,894 Answers
Check ur audio driver setting
  • 2 more comments
  • dewan nafees ahmed Jan 21, 2008
    sorry for late reply.
    you may have installed some audio driver like soundmax
    http://www.soundcard-drivers.com/compani..." target="_blank" rel="nofollow" >RealTek
    http://www.soundcard-drivers.com/compani..." target="_blank" rel="nofollow" >SoundMAX
    http://www.soundcard-drivers.com/compani..." target="_blank" rel="nofollow" >Intel
    http://www.soundcard-drivers.com/compani..." target="_blank" rel="nofollow" >Creative Labs
    or something else.. many cases this settings are avilable for changing on system tray itself. else you can find it on your programs list also.
    ok once you find it see if any cross mark is over the icon then its sure that your driver is disabled.
    even if no cross mark is there open it and see for audio configurations. change the audio configurations and click apply and then click OK.
    now play the audio.
    ur system has inbuilt sound card or extra sound card attached in the board??
    yes.. pauldonp was right.. you must not have rated me fixya... i mean you must not have accepted my solution. you must have waited for everyone to answer and then rate the one who answers it right..
    ok look at the driver software carefully..
    you may have got some driver software with your system.. it may be some software like sound max or realtec or something like that..
    now look at it carefully.. if its not showing any chance to enable it put your mother board disc in system and reinstall your audio driver..
    no no.. leave that probelm.. see that next post and reply to that.. if it doesnt work out we shall moe to next step
I ahve MSI u210 light, i want to know why is now takes long during booting... i ahve already formatted it but still the same.
Here are a few non-hardware-specific suggestions that have worked for me, not in any certain order, but I'd update the BIOS and try the first suggestion:
Unplug all of your peripherals, everything on the board (except HDD and RAM of course), and see if it boots faster. Only leave one stick of RAM in (primary slot), replace it with another stick each boot. If boots faster, replace everything one at a time, booting after each, until you find the problem device.
Try another HDD, make sure it's on the right SATA channel in the BIOS. Or even better, boot from a USB stick with DSL, Puppy Linux or Ubuntu (or whatever flavor you like). Watch the terminal on boot, see if it hangs on a certain device -this works in safe mode too.
Check your BIOS, make sure everything is legit, if it has a "fast boot" select it. May as well update the BIOS too, that may fix everything. You've probably done that though.
Poke it with a stick.
Nov 09, 2011 | Computers & Internet
I have an acer extensa 4230 which I reformated.I installed the audio,vga and rebooted the system.It rebooted fine.But upon installing a bios system driver,it requested for a reboot.After the system short...
It sounds as though the wrong BIOS has been installed or when downloading the correct BIOS there was a problem with the file and it is corrupt.
Apart from removing the BIOS chip and fitting a programmed one, there is not a lot else you can do except speak to Acer and see if they can help.
Regards.
Oct 20, 2010 | Acer Extensa 5620-4020 Notebook
Roland xp 50. everything works find except sound
Yes, he is full of it. For parts try Digikey.com, Mouser.com, and AntiqueElectronicSupply.
Jun 25, 2009 | Music
DVD/RW Drive
what else you have on the pc???
sound like you have too many attachment. try to go into the BIOS and see if there any setting you foregot to set.
Oct 10, 2008 | Computers & Internet
No boot up
Try removing all memory except one board. If it does not come up switch boards. Still no luck, check power supply if you can or switch it with another. A power supply checker is pretty cheap, 10 to 15 dollars, and well worth the investment, although it is not foolproof. Try switching PS off, physically remove the BIOS backup battery, then replace it and try again. That should have cleared the BIOS back to factory defaults. It sounds like a memory problem, but as a last resort, you might reseat the CPU. The CPU fan runs, yes? Can you get some other memory to try? Well good luck!
Sep 25, 2008 | ASUS A7V333 Motherboard
Lenovo fails to launch Windows, smbios failure
sounds like you may have a corrupt Bios.
Locate the manufacturers site, via another computer.
And see if they have a bios update to download.
*****Be careful, An unsuccesful bios Flash may render Your Computer Useless*** If you can enter bios at startup, find the page which allows you to restore setup defaults, save and exit to cmos.
Mike @ compurepair.
Mar 29, 2008 | HP Pavilion dv6000z Notebook
I CANT USE MY SECONDARY IDE
Format system and reinstall oprating system
if problem still continue so update bios
download from www.asus.com
Mar 08, 2008 | ASUS A7S333 Motherboard
Just purchased this motherboard, can't get bios to boot
just be sure...
take out everything, except the the power cable and the little speaker. try to turn it on. there will beep sounds. if not, the problem is the board. if there's sound, check connections.
also tell me the model of it, if possible.
after turning it on, check the power and hd leds, if they are on, or blinking.
check if hd and dvd are both jumpered as master. try removing both, just to try to get the bios working.
and one last thing, check it there's a intrusion jumper on board, if yes turn it off.
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
HP Pavilion a1000n (PS567AA) PC Desktop Logo
233 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
