Question about KitchenAid KEMC378 Electric Double Oven
"door" after closing the microwave and entering the desired time-the word "door" appears and nothing happens-the door is closed.
  • debonlong Jan 21, 2008
    thanks, troed that but it looks like the plastic "connection" inside the panel is pushed in too far-do I have to call for service?
  • Anonymous Mar 22, 2014
    It need to stop when door is close
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • KitchenAid Expert
  • 91 Answers
  • 770 Answers
Your door or interlock switch is not closing press on the door see if it stars if so you will have to check you alignment if not the switch could be bad you wuill need to open the ctrl panel to get to the switches unplug first
Posted on Jan 21, 2008
  • Gary Davd
    Gary Davd Jan 21, 2008
    if you dont know how to get into the panel yes you will have to call someone sorry i could not be more helpful
I Have a Whirpool Microwave Oven Combo Model RMC305PDQ1 sometime when the oven is cooking the oven latch closed and we can;t open
Despite what the owner's manual says, you should not open a microwave door when it's cooking. You should press the Pause or Stop pad first. Otherwise, you will shorten the life of your door switches.
If you're ever unable to pen the door, then you have a problem with the door latch, spring, etc. that needs to be investigted and corrected.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 27, 2013 | Whirlpool RBS275PD Electric Single Oven
The micro wave won't heat unless you raise the door when you close it. If you. Just close the door it will run but not heat.
The door switch is going bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 22, 2011 | Ovens
Hello we have bosch hbc 86 and every time i want to turn on the microwave it suddenly stops, even when im trying to defrost,it starts and then in 3 seconds it turns off, please do you have a solution for...
My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
Oct 15, 2010 | Bosch HBC 86Q650B Electric Single Oven
My daughter did something to the door... when you close the door and set the time and start the display reads 'DOOR' as if it isn't closed and it won't start. Thanks for any assistance. Whirlpool...
i have seen this a few times. the m/w portion has seperate fuses and sometimes the cartridge fuse can be blown. it is located inside the top above oven. hard to get to without pulling the unit and getting the top off of unit.
others have had a failure in the microwave control board.
Jan 10, 2010 | Whirlpool GSC308PRS Stainless Steel...
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
OTR Microwave Magnetron Fan and Interior Light Run with Door Open
Could be a defective door interlock or control board.
Mar 06, 2017 | Ovens
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
Microwave
This would most likely caused by a door switch. It is either not being activated by the door not closing tight enough or the switch itself has failed
Jul 10, 2007 | GE Profile JTP95 Electric Single Oven
KitchenAid KEMC378 Electric Double Oven Logo
315 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
