Question about Mitsubishi WD-52725 52". Rear Projection HDTV
No picture, only the green light flashes on the 1080SI
Tried to turn on tv and got no picture only the green ligh flashes on the panel.
    President:
  • 4,402 Answers
Http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 21, 2008
Planar PDP-42BK 42" Green Light just Flashes no picture. I am having the same issue. TV worked great yesterday than today I get a flashing green ligh and no picture.
remove all the connection and try to fit somewhere else. the socket which is directly connected to the wall.or then it could be the tube problem inside call some service technician.hope this will help you.
Jun 06, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
19
What else is it doing are there any lights on or flashing?
Dec 19, 2011 | Sanyo DP19648 19 in. LCD TV
Green light on, can hear the program but the screen is black. No picture
Hello
Check its back ligh inverter board and backlight CCFL tubes.
This is the picture of the backlight inverter board to your TV. There is no repair to it other than replacing it as card basis. 1_9_2012_8_09_23_am.jpg
Oct 24, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
I went to turn on my tv tonight and it started to come on - then did not.. a blinking red ligh is where the green light usually is - I tried to unplug it and re plug it in.. no help
When you turn the TV on, does it attempt to come on and then off? Does the light go green when you attempt to power up and then goes red?
Jan 31, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Philips 20PF4121 LCD tv no picture but flashing error codes
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Jul 09, 2009 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
208 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
