Question about Legacy Audio LA770 Car Audio Amplifier
La1498 amp how do i bridge i dont under stand
    Sergeant:
  • 203 Answers
If the amp is bridgeable then u should see lettering where the speaker outputs or the channels are and you will a symbol saying bridged and then u can see a + and - symbol with lines going to the other channels. In other words they call it bridged because you are jumping from one speaker output to the other, usually bridging an amp consists of Left - to Right + or vice versa.
Posted on Jan 28, 2008
How do I install a Rockwood AMP-326 amplifier? I'd like to bridge it.
Rockwood was a very low level brand. Alot of their amps were not brigeable. If bridge able the bridge terminals should be marked (usually the positive of 1 channel and the negative of the other channel). Under no circumstances bridge to less than a 4 ohm load.
Jul 17, 2016 | Rockwood Car Audio & Video
Guages on 87 rx7 gxl dont work
I'll help with the brake lights. 1st check fuse, 2nd there is a brake light switch located at the brake pedal you will need to get under the dash & find it. Remove plug from switch & bridge plug with wire If the lights come on the switch is faulty (have the ignition on while doing this) 3rd check brake globes it is possible all are blown.
Jul 05, 2012 | Mazda Cars & Trucks
Need instruction manuals for thomas the train shake shake bridge and midnight ride.
Here is how Shake Shake bridge goes together:
On the bottom of each piece is a letter. Here is how the letters fit together to form an oval. Bridge is A and the other straight track is F you also have 2 B's & 2 C's
going clockwise: A - B - C - E - F - D - C - B
The 2 tall supports go under the junctions at B & C on either side and the small supports go under the junctions at C & D and C & E
Jan 26, 2011 | Toys
How to lower the blade it's not cutting all the way thru..stand. 12 inch tile..help please
a temp fix,put a thin rubber mat under your tile.my bridge saw does plunge cuts & has a knob on side of cutting head, your blade must have been changed somewhere even if changed with the same size blade some vary in overall size,good luck
Nov 05, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
Gerard
May 13, 2010 | Pyle PT-2000 Amplifier
不读碟,&a...
random **** me dont under stand
Feb 25, 2010 | Computers & Internet
My amp and subs work but the subs dont sound very loud. how do i adjust my Pyle PLA4340 amp and fix this problem
Hello polarisracin,
You need to bridge 2 of the amp channels to each 4 ohm sub to get the most power from the amp. Bridge channels 1/2 to one of the subs and channels 3/4 to the other one. But the amp is only rated for 75 watts RMS per channel and Pyle products are sometimes rated higher than their real capabilities. So, even bridged and with the rated output, you'll only be getting at most 150 watts from a pair of bridged channels. That's not much for a sub.
Hope this helps.
Oct 01, 2009 | Pyle PLA4340 Car Audio Amplifier
I want to bridge my icbm 781 amp i dont know how to bridge them
it is already "bridged" it's a monoblock amp, 1 channel, if you're trying to get more power, lower your ohm rating..here's a guide to wiring subs for different ohms: http://www.crutchfield.com/S-vXEiF19AwhE/learn/learningcenter/car/subwoofers_wiring.html
Jul 31, 2009 | Performance Teknique ICBM-782 Car Audio...
Have Jensen A1000 how do I bridge it?
that model amp if am not wrong dont need to be bridge its a mono block amp
Apr 09, 2009 | Car Audio & Video
Need help bridging
First check your gain it may be turned down. I personally dont bridge speakers. I put each speaker to its own channel on the amp.Make sure positive to positive and negative to negative. Try hookin up two speakers to the amp (not bridged) and turn your gain up around half way. Make sure you amp is switch to lowpass not high since most amps have crossovers built in now. The more speakers you have the less output from each speaker from one amp youll get.
Mar 02, 2008 | Kicker 01C8VR4 Car Subwoofer
Legacy Audio LA770 Car Audio Amplifier Logo
67 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
