Question about Legacy Audio LA770 Car Audio Amplifier
Bridgeing how do i bridge i dont understand how it works
  • Anonymous Feb 01, 2009
    do you have wiring connection for one subwoofer and two speaker for lecacy red series la 770 500 w x 2 amp?
U use the first live out put and the last out put wich should b a negative whick will make the amp run all its power into the sub
Posted on Jan 22, 2008
6ya staff
SOURCE:
Hp nx6110 laptop keeps hanging but works well when pressed on top of touch pad or hard drive.
Only if you have knowledge on hardware Laptops you understand. The procedure go as follow:
Unscrew the motherboard completely.
Identify the North-Bridge BGA IC (BGA= ball grid arrays) under the mouse region.
Get an SMD Rework Station.
Suspend the board on a surface which cannot be affected by heat and held firmly whereby under the North-Bridge BGA IC is opened.
Use your SMD Rework Station to generate heat  evenly beneath the region North Bridge IC and press gently without being bridged.
Mind you 90% risk is involve.
Oct 07, 2009 | HP Compaq nx6110 PC Laptop
My amp and subs work but the subs dont sound very loud. how do i adjust my Pyle PLA4340 amp and fix this problem
Hello polarisracin,
You need to bridge 2 of the amp channels to each 4 ohm sub to get the most power from the amp. Bridge channels 1/2 to one of the subs and channels 3/4 to the other one. But the amp is only rated for 75 watts RMS per channel and Pyle products are sometimes rated higher than their real capabilities. So, even bridged and with the rated output, you'll only be getting at most 150 watts from a pair of bridged channels. That's not much for a sub.
Hope this helps.
Oct 01, 2009 | Pyle PLA4340 Car Audio Amplifier
Have Jensen A1000 how do I bridge it?
that model amp if am not wrong dont need to be bridge its a mono block amp
Apr 09, 2009 | Car Audio & Video
Wet54g will propperly communicate to a cisco 1310
make sure you switch anything that says 'proprietary', or is just not standard 54g with the wireless settings.
Some manufacturers will put in auto-discovery services that only that same manufacturer of wireless access point will understand, this can sometimes cause problems for bridge communication.
Mar 20, 2009 | Linksys Wireless-G WET54G 802.11g/b...
No internet connection
bridges sometimes use mac cloning to clone the device that is attached to it. go into bridges config page and disable this feature and also make sure to select dhcp since bridges will also use a static ip as well. i just hope this helps alittle. i dont have your exact model of bridge here so if you can comment on it i can get back to you and try to help further
Feb 05, 2009 | HP Computers & Internet
D-Link Di-604 bridge?
I had no problem finding the Di-604 on the D-Link site.
http://support.dlink.com/products/view.asp?productid=DI%2D604
Dec 16, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Connect befw11S4 with wmb54g
You dont need to open ports on the router. Just configure the music bridge with the same wireless settings as your router so that it will work.
Jul 24, 2008 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Tring to bridge my 2wire
Why do you need to bridge?
Can't you use both devices off the one router?
usually to bridge you would need, effectively , 2 extra access points to set as the bridges, they then connect to the other routers, allowing communication between the 2.
I do know 2wire is slightly different but you would still need something to act as a bridge on the netgear end.
I still don't understand why you need both routers running. Connect both your computers to the same router which has the internet connection.
Hope this helps
Tony
Feb 28, 2008 | 2wire 2700HG-B Router (2700HGB)
Legacy Audio LA770 Car Audio Amplifier Logo
Top Legacy Audio Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Professor_V
Professor_V
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
