Question about Frigidaire PLEB30T8A Electric Double Oven
How do I replace the probe
The top oven won't hold its temperature so I ordered a new probe/oven sensor. It is a different probe from what is in the oven now. A notice came with the part stating that I need to cut the quick connections and hardwire the new sensor using ceramic nuts. I can't pull the old probe out far enough to find the end of its wires. Do I REALLY have to remove the entire double oven from the wall to access the full length of the sensor's wiring?! Or can I cut the wires that are easily accessible and hardwire it with the new probe from there? Does the length of the probe's wire have an effect on the oven't ability to accurately regulate temperature?
  • 770 Answers
Yes and no the reason they ask you to cut them is the lenght of the wire does affect some of the probes (thermistor) it reads resistence and the longer the wire the more it will read if you want it to be for sure your model is this type do it the right way and pull the oven if you want to cut it in place then try the oven like that if you are happy with the temps then leave it the reason the wire wont pull out the is a zip strap holding it in the wire bundle behind the back wall.Hope this helps
Posted on Jan 21, 2008
MAYTAG OVEN ERROR CODE F3
Hi Janine.
F3 means "Shorted oven temperature sensor" and it is returned when the oven electronic control detects a wrong impedance value from the oven temperature sensor circuit.
The oven temperature sensor is a probe located inside the oven cavity. The sensor can be removed from the oven and tested using a multimeter set on impedance. The impedance reading across the two sensor's contacts at room temperature must be about 1100 Ohms. Impedance increment rate is 100 Ohms more for every 50 degrees temperature increase. If the reading is sensibly different from this value the sensor must be replaced.
Here the replacement part:
Long Oven Sensor Kit
The sensor is indicated as part number 11 in the exploded view available here.
The sensor is held by two screws. In order to replace the sensor disconnect power, disconnect the connector attached to the sensor, undo the two screws and remove the sensor. Perform operations in reverse order to install the new sensor.
Regards.
Ginko
Jan 15, 2012 | Maytag Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Jul 15, 2011 | Frigidaire Ovens
F2 and a beeping noise just replaced the 350 degree sign on my oven as I was baking supper. What's up?
This is a fault code for the oven temperature sensor.
The temperature probe is secured in the top of the inside back wall of the oven. Unplug the range to disconnect electrical power. Open the oven door and remove the racks. Remove the screws that secure the oven temperature sensor probe in the back wall of the oven. Carefully pull the sensor into the oven until you get to the wire harness disconnect plug. Unplug the sensor probe. Do not let the wire harness **** back through the opening in the back of the oven. Check the resistance of the probe with a volt/ohm meter. At room temperature, you should measure about 1100 ohms of resistance. If the resistance is bad, replacing the oven temperature sensor probe. This part can be purchased at www.appliancehelponline.com
Mar 23, 2010 | Kenmore Ovens
My oven displays error f31. It beeps and when I press clear the beeping stops. But if I try and set the temp it reverts back to f31
The F31 fault code indicates a problem with the oven temperature sensor probe. The temperature probe is secured in the top of the inside back wall of the oven. Unplug the range to disconnect electrical power. Open the oven door and remove the racks. Remove the screws that secure the oven temperature sensor probe in the back wall of the oven. Carefully pull the sensor into the oven until you get to the wire harness disconnect plug. Unplug the sensor probe. Do not let the wire harness **** back through the opening in the back of the oven. Check the resistance of the probe with a volt/ohm meter. At room temperature, you should measure about 1100 ohms of resistance. Since you are getting the F31 fault code, you will not likely measure this resistance. If the resistance is bad, replacing the oven temperature sensor probe .This should fix your problem. You can order this part from the www.appliancehelponline.com If the resistance of the temperature probe is normal (1100 ohms), then I recommend that you access the electronic oven control board in the console (with the range still unplugged ). Remove the upper back panel. Pull the P5 connector on the control board and measure the resistance through the purple wires (pins 12 and 13 as shown below) to check the resistance of the temperature probe through the circuit that connects to the board. If the resistance is drastically different than the 1100 ohms measured at the probe, then the wire harness is bad and will need to be replaced. If you measure the proper resistance through this wiring harness at the control board and the connections are good, then the electronic oven control board will need to be replaced.
Mar 23, 2010 | Ovens
F30 error code
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Error codes how to reprogram oven electric oven the code F30 appears on led display
Hi
The F-30 error code states its a Open/shorted probe connection. Check resistance at room temperature & compare
to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor
wiring harness between EOC & Sensor Probe connector. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Also you can see the probe in the oven in the top left or right corner. It is pencil sized and about 5 inches long. You would need to get to the back of the oven to replace it. It has two 1/4 in screws that hold it in place. You then plug it into the control board and you are ready for baking again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Frigidaire GLEB27S7A Electric Single Oven
F 10 code when I try using oven
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
F30 - F10 error messages
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Jul 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire PLEB30T8A Electric Double Oven Logo
124 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
