Question about DeLonghi DCR902T Coffee Maker
Coffee Temperature Is there a way to increase the temperature of the coffee during brewing as well as the warming surface? Our unit appears to brew the coffee at a cooler temperature than other typical coffee makers.
  • Anonymous Mar 17, 2014
    prime appears in window and coffee will not brew
    Master:
  • 619 Answers
Hi , if you could open the below cover check the heating sensor might lose connection / if their is possibility to unscrew the sensor try to applied heat sink grease available in appliances repair shop , make clearance to boiling tank thick two papers in applying sink grease,same in warming surface.
Posted on Jan 21, 2008
Brews good hot coffee but warming plate has stopped heating! Are replacement elements readily available or could it be a fuse...??
The DCC-1200 has only one element, that both heats the water for brewing and keeps the carafe warm. If you're brewing coffee then the element is fine and the suspect part is the Thermistor. Another forum suggested this was a Vishnay NTCLG100E22245B, available from DigiKey (their part # BC2467), connected to the control board with thin yellow wires. The same forum suggested that this thermistor should test at 220K ohms at room temperature, dropping to 20K at about 220F.
Nov 17, 2015 | Cuisinart DCC-1200 Coffee Maker
Coffee brewing very weak
possible ways to remedy this problem:
problem of weak beverage
solutions:
1. Filter Type-BUNN paper filters must be used
for proper extraction.
2. Coffee Grind-A fine or drip grind must be used
3. Sprayhead-A six-hole stainless steel spray-
head must be used for proper
extraction.
4. Funnel Loading-The BUNN paper filter must be centered in the funnel and the bed of ground leveled by gentle shaking.
5. Water Temperature- Place an empty funnel on an empty
dispenser beneath the sprayhead. Initiate a brew cycle and check the
water temperature immediately below the sprayhead with a ther-
mometer. The reading should not be less than 195F (91C). Adjust
the control thermostat to increase the water temperature. Replace if necessary.
Apr 11, 2013 | Bunn 392 Pourover Coffee Maker With 2...
How to increase temperature on model BCM120. The coffee is not hot enough after brewing. Is it possible to increase the temperature on the thermostat.
There is no temperature adjustment for the heating element under the carafe.
The Instruction Manual says:
If coffee is too cold, machine not preheated, cups not preheated, milk not heated enough (if making a cappuccino or latté)
Jun 12, 2011 | Breville Coffee Makers & Espresso Machines
Fetco cbs-51h coffee maker not heating hot enough. turned thermostat all wasy up. coffee luke warm.
It can be the Temperature sensing probe, heating element or a loose/burned wire connection.
Adjusting the brew temperature is not going to help
Jan 17, 2011 | Coffee Makers & Espresso Machines
I have a keurig b 60 brewer and i don't feel the water is hot enough. i just got it last night 12/23/10 can u suggest anything?
Sorry to read about your problem, I hope this helps you out.
ProgrammingBrewTemperature (187°-192oF)
The Brewer brews at a preset temperature of 192°. You can adjust this temperature down by 5 degrees if you prefer a cooler cup of coffee, tea or hot cocoa. Simply follow the instructions below.
1. Press the Menu Button on the LCD Control Center five times to program the Brew Temperature feature.
2. The LCD Control Center will now display the programming options with a small arrow next to "SET BREW TEMP" (fig. 15). Also, the temperature 192° (initial setting) will be displayed at the bottom of the LCD Control Center to indicate the current temperature setting.
3. A minus sign will appear over the Small Cup Button and/or a plus sign over the Large Mug Button. Use these buttons to raise or lower the temperature one degree at a time.
4. Once you have reached your desired brew temperature, press the Menu Button once to exit the programming mode. "BREW TEMP SET" will be displayed in the LCD Control Center if you have changed it from 192°.
5. To change the brew temperature again, repeat steps 1 through 3 to change the temperature up or down, remembering that the temperature can only be between 187° and 192°.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Keurig B60 Coffee Maker
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Coffee brewing comes out in a fast steady stream when brewing, coffee doesn't brew properly and comes out weak. taste like unbrewed.
If it comes out in a steady "stream" it sounds like the sprayhead is missing. The sprayhead disperses the water out and evenly over the grounds.
If the sprayhead IS in place then it could be a temperature problem. If the temperature is not hot enough the coffee will not brew correctly.
Sep 06, 2010 | Bunn Coffee Makers & Espresso Machines
When i make coffee sometimes the water that comes out is cold or luke warm
The brewer has not had enough time to reach its operating temp (usually 7 mins after a brew cycle). If that is not hte case then the machine needs to be descaled.
Feb 18, 2010 | Bunn VPR Coffee Maker
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
DeLonghi DCR902T Coffee Maker Logo
508 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
