Question about RCA DRC246N DVD Player
RCA DRC246N Power problem
I am not getting any power on my RCA DRC246N dvd player. I checked the fuse and that was ok. Any suggestions?
  • Anonymous Feb 28, 2008
    Standby light comes on, but it won't power on.
Upon visible inspection, C411 in power supply was swollen. 1000 microfarad 10Volt. Replaced with slightly larger 1000 microfard 25 volt I had on another old board. Powered on ........ works fine.
Posted on May 02, 2008
I had this problem after only a few months of use! There were some bad capacitors on the power supply board. Replacing them fixed the player. They used cheap electrolytic capacitors on this unit; check them all while you have it open.
Posted on Apr 14, 2008
No power to the dvd player.
And you check the dvd fuse or the remote wire who comes from the stereo
Jul 18, 2010 | Sony MV-900SDS Car DVD Player
No power
Is the fuse located before or after the main power switch?
If the answer is before the main switch, then maybe you should also check the main power switch (dirty contacts - these may cause insufficent voltages from the power supply).
Note that the (electrolytic) capacitors can be faulty but will not have visible damage, so check the DC voltages on the power supply output and try to replace the associated capacitors if the voltages seem to be too low (usually, there will be 12 and 5 volts outputs, sometimes a 3 volt output on some brands/models).
If it turns out that these voltages are not present at all, then there may be damage to the transformer driver IC (i'm assuming this is a switching power suply) - see if there is any AC voltage present at the secondary terminals of the transformer, if there is none, then the primary is most likely not being driven by the 110 V and this points to the driver IC as the possible cause. It may also be some other component in the primary section, but you said you've checked them out, so i don't know what else to suggest.
Hope you can fix it.
regards
Triarcuate
Sep 29, 2009 | RCA DRC220N DVD Player
I cannot get power on dvd player is plugged in properly
Check to make sure the fuse hasnt blown in the Plug, if thats fine then there is a problem with the power board inside the dvd player, this could be down to a blown internal fuse which has blackend due to a short circuit, then thats an indication that some of the parts on the DVd player power board have shorted.
jon
Aug 12, 2009 | RCA Televison & Video
Rca lyra 3030 will not turn on
If your handy open it up and check the master fuse on the power supply. If it is good then the power supply is bad and not worth fixing. DVD players are throw away items now a days. But Id check the fuse thing as this is most commly the problem with electronics that wont even power up.
Jul 25, 2008 | RCA Televison & Video
Samsung v5600
be sure that have a power in your outlet. if fuse is good try to check the diodes on the power supply, some diodes may be open.
Jul 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
How do i get the magnification symbol off?
hi i dont think u can its a company requirement sorry
Jan 01, 2006 | RCA DRC246N DVD Player
Televison & Video Logo
127 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
