Question about HP Compaq Presario V2000 Notebook
Won't turn on
I had my laptop on yesterday morning and it was working fine. Turned it off, left for an hour, came home and it won't turn back on. I've taken the battery out and tried to just use the AC adapter, still no power. I've tried it in other outlets, nothing. I've taken both the battery and power plug out, let it sit for 5 minutes, put it back together, still nothing. No lights, nothing. It's less than 2 years old, could the adapter be dead? I don't want to buy one if that's not the problem.
    President:
  • 4,402 Answers
*Unplug the AC cord
*Remove the battery
*Locate the memory cover on the underside of the notebook
*Unscrew the one or two screws securing the memory cover, and lift up to remove the cover
*Gently slide (away from one another) the metal retaining clips that hold down the module.
*The module should pop up
*Remove the module
*Reinstall the module (removing and reinstalling the module is apparently enough to rectify the contacts)
*Replace the module cover and the battery
*Attach the power cord
*Try to power up
Posted on Jan 21, 2008
2009 Honda Shadow Aero ran fine yesterday, stopped for about 3 hours would not start last night. Turned over would not start, help?
sounds like a CDI issue!
could also be an ignition switch or run/stop switch issue.
is the bike lacking any power when running?
Maybe stator pick-up coil as well.
Have electrical components checked at the dealer.
May 24, 2014 | 2004 Honda VT 750 Shadow Aero
2005 kia sorento not starting
Sorry you are having a problem. I would doulble check that the idle air connector was plugged in and seated well. It's the square connector below the throttle body. I also supect you missed a vacuum line when reinstalling the Throttle body.
Mar 24, 2017 | 2005 Kia Sorento
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
My car has been running fine. Starts each morning once to drive kids to school. An hour later for me to drive to work. But for the last two mornings won't start back up after working 4 hours. I noticed...
Sounds like the alternator is going out the slow way.
Youre kinda lucky because almoat all alternators go out without warning.
Most Autozone shops or places like it will run a test for free.
Good luck,Gary
Sep 23, 2011 | 1992 Honda Accord
What does it mean when i turn my laptop on the screen is white.
I can't tell you what it means but it happened to my laptop this morning.
After reading tons of "solutions" nothing worked. Finally, I turned it off, went grocery shopping for a couple of hours and when I came home and turned it back on and it seems to be fine.
I am, however, going to make a recovery disk like the computer has been suggesting since I got it.
Dec 16, 2010 | Epson Viewsonic ViewPanel VE150M Monitor
I have the Harman Kardon HK3370,I have no sound was working fine this morning before I left for My Job.after a 12 hour shift came home turn it on and have no sound check speakers and all are fine.
Make sure speaker switch is turned on, when it is the small box on the side of the display will illuminate. Make sure the tape monitor is off. Check that no one pulled out the pre-out to main-in bridges in the back.
Jun 16, 2009 | Harman Kardon HK 3370 Receiver
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
HP Compaq Presario V2000 Notebook Logo
940 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
