Technics SU-V2 keeps cutting out
I have a technics SU-V2 amp wired to 2 reli retro powerful bose speakers and the sound just cuts out for no reason (display stays on) ever so often im a bit of a novice and suspect the amp may not be powerful enough for the speakers but it sounds really great until it cuts out really need some help cheers
  • britishgent Jan 23, 2008
    does this mean i need a new amp or is ther a cheaper solution
  • Anonymous Mar 12, 2014
    no audio out in speakers
    Scholar:
  • 57 Answers
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
Su-2760 will not work. gets a flash of power, turn off
Sounds like the safety circuit is tripping cutting off the power. Most probable cause a short circuit on the main power amp board, causing an overload.
Apr 01, 2014 | Technics Audio Players & Recorders
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
Technics su v2 amp will not turn on, other components work fine (turntable, radio, cassette player, speakers). I think it maybe the power supply. Tip? Opinions?
Check inside power supply fuse, it may be just that but if you put a new fuse and blows you may have a power output devices failure, let me know your results.
Oct 03, 2013 | Audio Players & Recorders
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
I have a technics SU-v500m2 amplifier connected via the aux input to my pc, i wish to link another amp to the same input, is this possible, and if so how?
Let's establish which is the IN and which is the OUT here. The PC is a Line Level source so its OUTPUT would feed one of the amp's Line Level INPUTs.
What's the second amp going to do in your scenario? Something other than the normal stereo channels; something multichannel (if your PC supports it); or just more speakers supported for the PC to feed?
An RCA Y-connector pair would share the stereo output of the PC with multiple Line Level destinations.
If a second amp with its own volume control is intended to share the same two channels with the SU-V500 it could also be slaved off the back of the SU-V500 wih an RCA patch pair exiting the Tape 1 or 2 REC(OUT) jacks. The second amp would receive full-volume audio from whatever source the SU-V500 is playing. Just don't activate the selected Tape monitor on the SU-V500 or you will cut off the source to both amps.
Sep 24, 2011 | Technics SUV500 2-Channel Amplifier
Can a technics su v670 be wired up with a technics power amp a800s mk II?? what im thinking it doubles up on the power the wattage to each channels? am i rite? the suv 670 is 90 watts per channel and the...
"im no proffetional at this". Really?
If you looked at the manuals for either product you would NEVER find a recommendation to use one amplifier's speaker input to drive the LINE LEVEL (very small) input on another amplifier. Speaker outputs are for driving speakers or amplifiers designed to accept speaker-level input (like some self-powered subwoofers). In no case is the power of the originating amplifer BOOSTING the power of the driven one.
You should do some reading on how amplifiers work before you blow something up and come asking for advice on how to resolve it.
Sep 02, 2011 | Audio Players & Recorders
Hi. Having problem getting sound from the little tweeters on my technics sb-1970 speakers. They are 3way linear phase speakers 90w each. I took the tweeter out and every wire is connected. Tried pushing...
If you went so far as looking at the wires on the tweeters you could have taken an ohmmeter to them to see if they're blown.
Is there a back story to this? What preceded the investigation?
Feb 07, 2011 | Audio Players & Recorders
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
912 people viewed this question
 Grubhead
Grubhead
