Remove the shower screen and screw then try if water flows clean shower, if not remove diffuser screws and check spring and valve to make sure it is not blocked.
take basket off, and unscrew sprayhead, clean out holes and rinse spray head and screw it back on, then try to pour some water thru, if it comes thru, then brew some coffee
If the spray head is clean and clear and you have run the spring the the brew tube till you can push it almost all the way in (leaving only 1/4") then it should not have issues.
Remove the shower, then the 2 allen wrench screws for the diffuser, careful do not loose the spring ad valve seat that is above the diffuser, now turn machine on to see if water will come thru, if water flows, problem is either screen or diffuser blockage, if no water then you need a stronger descaler because blockage is in the boiler, at the solenoid or from the pump. Most likely in the boiler, if you have a boiler gasket go ahead and open the boiler to clear the blockage.
We were having the same problem and this worked for us, right from an insert that was included with the manual.
1. Fill tank with water 2. Remove the filter holder 3. open the steam tap 4. press the main switch and the coffee switch at the same time 5. close the steam tap as soon as water begins to flow 6. If after 30 sec. no water comes out repeat the operation. 7. when it starts, draw off 4 cups of water
