Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable 2 print', What do I do? Reset maybe? How would I reset the printer?
Comment by Firemann, posted on Jan 22, 2008
Comment by Firemann, posted on Feb 04, 2008
11 Other Users Have The Same Problem
Comment by lakota8, posted on Jul 24, 2008
I have the same problem (unable to print,troubleshoting etc...) and I made all steps you adviced(menu,mono start,arrow 4 times,77,99...)and sth happened: three buttons(fax scan ,copy are lighting)and it doesn't work at all,what to do???
Comment by Guest, posted on May 25, 2008
pleess mfc 9420cn machine error 21 and factory reset ?
Comment by Guest, posted on May 23, 2008
I have a Brother MFC-8440 and the maintenance fault # 7 came up. I just fixed the problem pressing the menu and select buttons at the same time then turn on the printer main switch. After this the fault completely clear and is working fine since. Does any body know if that was a proper way to fix this problem?
Comment by Guest, posted on May 17, 2008
Have the same message but the steps dont seem to fix it. Rang Brother and they will get back to me next week. This is a fax needed 24/7 so 2-3 days for a response sucks! Going to buy a new fax from a reputable company with a 24 hour support service.
Comment by Oto Alan, posted on May 12, 2008
I was printing on the MFC 9240CN and got a message "no OPC belt". I took the belt unit out and put it bcak in and printed 10 more copies. Then "unable to print" message so I followed the manual and switched the printer off, waited switched it on and printed another 10 copies. THen got "no OPC belt" error again. I removed the OPC unit wound it on a little and put it back to print another copy. I am not sure if I've fixed the problem though.
Alan
Was this solution helpful? Show your Appreciation by rating it:
The Users guide did not help at all. After considerable on line research I found that the PF Kit is only on machines with the second paper tray -- so my machine did not have a PF KIt. I went to the trouble of obtaining firmware update "version j" and installing it It did convince the machine that there was NO PF KIT, but did not solve the problem. Next, I replaced the OPC belt I was using with one that I bought recently which makes streaks. I had spent over $300 in response to the message which said "Replace OPC Belt cartridge but the new one started making streaks after about 300 pages, so I put the original back in - [it made white marks on a color picture -- but I can live with it ]. When I put the defective [but low page count] unit back in, the message seemed to have stopped. So I have 4 choices: 1) use old cartridge - run a few pages, get message, turn off for several hours, start again; 2) run with newer OPC BELT, get horrible streaky pages and faxes I can't read; 3) Spend another $300 and hope I get a good OPC BELT. 4) try to figure out how to defeat the page count feature on the original OPC BELT cartridge. I cannot find any phone number or email link to complain. I feel that this machine is a joke on the public. SHAME ON BROTHERS. I HAVE BEEN MPCed.
Rating: 0%, 0 votes
Post a New problem for Brother MFC-9420CN All-In-One Laser
Email this problem
Can you Help with these Printers problems?
Printer locked up
brother mfc 9429cn
error message :"...
Can't print
MFC9420 Unable to Print
11 Other Users Have The Same Problem - Continued
Comment by kalklamou, posted on Apr 23, 2008
It was after a routine maintenance that my MFC-9420CN start
Comment by Guest, posted on Mar 09, 2008
page prints with a wide smudge down the middle
unable to print..what is the solution
Comment by Treshon, posted on Feb 24, 2008
i keep getting an arror message sayin No opc belt but the belt is very new what do i do to stop this message
Comment by TomZ, posted on Feb 23, 2008
I see Unable to Print' problem also. Where is the Mono start button?
Comment by Guest, posted on Feb 10, 2008
"unable to print" still appearing after following the steps describe above when I press "77" it will try to print page and the error reappear
