Question about Samsung DVD-HD950 DVD Player
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
I have just bought a Samsung HDD-DVD Recorder and I have .avi files on cd copied from PC which play fine on the pc but they do not play on the dvd player after pressing play it loads then makes a sound and another sound, like a fast frwd audi sound and then the screen just stays blank until I press stop. I have HDMI cable connected between the TV and DVd and Red/White and Yellow audio and video cables connected.
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Posted on Jul 02, 2009
    Problem Solver:
  • 7 Answers
Go to Samsung website and download latest Firmware copy to disk and insert into DVD Player, then it will update itself.
Samsung Addy:-
Posted on Feb 11, 2008
Samsung HDD SH853M doesn't work
What type of cable are u using to connect the TV and player.
Check those first, and reconnect if in doubt and post back
Nov 17, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Vhs to dvd
Get a TV card (PCI, USB or PCMCIA); plug an AV cable from the back of the VCR to the TV card, then use the software supplied with the TV card to write the input to an AVI file... The playback has to be 1 to 1,
write the AVI to a DVD using any DVD, or VCD creation software... If you want multiple copies copy the DVD, don't re-write it from the source material (it is quicker)... And then delete the source AVI.
If you don't have a TV card but have a digital camcorder see if it supports AV-IN. When you do this I go from my VCR to the camera then to a firewire port on the PC. The camera acts as a bridge. you can burn it with Nero 5.5xx Get very good results this way.
May 21, 2008 | HP Pavilion dv9000z Notebook
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di mio jvc dr mh30..di 6 mese e roto trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
Copying problem
if u can copy it to hard disc, then later burn the CD in vedio mdoe and its done.
Apr 11, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
DVD copies stop playing after 30 minutes
sounds like a gear is broke moving the transverse motor
Jan 10, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Likely if you burn the MP3's to a CD or DVD and finalize the disk.- try it.
Jul 31, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Samsung DVD recorder, dvd-r121, In south africa
some avi's are in native format. make sure the avi file that you are trying to play is in divx, mpeg 4 format.
Jun 03, 2007 | Samsung DVDR120 DVD Recorder
Panasonic VCR/DVD Player
You need to convert the .avi files to the MPEG format with software. Just renaming the file will not work.
May 29, 2007 | Panasonic PV-D734S DVD Player/VCR
Samsung DVD-HD950 DVD Player Logo
1,092 people viewed this question
Jerry Greenberg
Jerry Greenberg
