Sharp AR-5320 Black and White Copier Logo
Posted on Dec 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
H4 READING H4 FLASHING
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Sharp Master 1,449 Answers
  • Posted on Dec 16, 2009
Sharp Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614474
Points
3628
H4 flashing mean fuser unite fault.Fix it # interrupt C interrupt 14 press start key machine on/ off.If it are not fix change thermostat or Heater lamp.
4helpful
What does Olivetti d-copia 120 error message H4 mean?
  1. H4 00 means Heat roller abnormally low temperature
3helpful
My copier is flashing the code H4
I have a tip posted here on Fixya that resolves this problem easily.
Here is the link:
http://www.fixya.com/support/r4376849-sharp_al_series_copier_h3_h_3_code_reset
If it works for you then please return here and provide feedback for me that I was helpful.
Thanks
3helpful
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
H4 code flashing. turned it off and back on...still flashing. anything else we could try?
See my tips and tricks solution for this problem on this site. Just search for Sharp AL series H4
I have a h4 recorder and when i turn it on i get a no card reading .changed card still same message
Are you using the type of card recommended in the manual? There's also an update here that you might like to have:http://www.zoom.co.jp/english/download/software/h4.php
Flashing H4 - fuser problem but can't get into diagnostics
You have to repair the problem before you can reset the code.... The problem is that the fuser heatting lamp is most likely blown or "Candy Canned" or you may need a thermal fuse or thermister.. Good Luck finding the parts.....
2answers
H4 flashing
to access the service mode.
enter the folowning keys .PROGRAM .ITEREPT .CLEAR INTERPT MUST BE IN SEQUENCE
THAT ENTER NUMBER 14 THAT START BOTTON
HOPE THAT HELP
2answers
H 4 FLASHING, MANUAL LOST, AL-1220 Sharp Photocopier
Try to press #, Interrupt, C, Interrupt in that order and enter 14 then press copy key.
1helpful
Activate pairing mode
Holding down the multifunction button for eight seconds puts the unit in pairing mode and an LED lets you know the status of the headset. Flashing blue and red means the H4 is in pairing mode, flashing blue means it is paired and flashing red means the H4 needs charging.
Aug 10, 2008 • Cell Phones
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
