Question about Scanport GEM GL-821A/B 17" Flat Panel LCD Monitor
Scanport gem gl-19072
Brain dead
  • 180 Answers
Suspected the main board / invertor.
Posted on Apr 22, 2008
Is it a sin to use cannabis?
no
just plain brain dead as your brain becomes dead after continued use
May 10, 2018 | Computers & Internet
My infomation center on my 2007 suzuki xl7 is not working ,is there a way to reset it or what would cause it not to work
my Cluster DIC is dead. is true name.
driver info center display.
No, and yes
post 2 by U
its just a data display
all brain boxes in the car talk to it on
an network
why not elaborate what the DIC display does
its totally dead
fuses.
ever use a desk top computer
same answer for the DT display
it sees the whole world of things
its just a display brain.
it gets vasts amounts of data from all brains in car
it even computes, MPG, from live data
and tire pressures. endless,complexity here.
it's just a data display
fuses,first did i say fuses yet?
and #2 scan it
buy a scanner
rent one
barrow one
or do like 99.9% do today get your shop to do that.
Feb 20, 2017 | 2007 Suzuki XL-7
Young Virginia Democrat Registers 19 Dead People to Vote for Hillary ?.
She is allowed to have a few as anyone voting for Trump would have to be brain-dead anyway LOL
Seriously, that happened, but he got caught.
Oct 02, 2016 | Miscellaneous
Can TV fix your brain
no-- once brain dead forever brain dead
Jun 27, 2015 | Video Game Consoles & Games
Where is flasher relay on 2007 jeep patriot
Nice guess, but buzzzzzzzzzz , back to go. do not collect 200 bucks.
sadly no symptoms only my wasted time on an easter egg hunt.
hazards fail on all 4 corners, or just dash lamps fail.>????
what? the cluster has a brain too, an can fail even if tail lights flash.
the Blink DRIVER IS INSIDE THE TIPM. (under hood)
did you scan it first?
if not you many be on a wild goose chase.
MK jeep , it's in the FSM book. read it or log in to alldata.com?
there is no such thing on 07 (no relay)
(how it really works is...) bar stool, yak.
the steering stalk is now a computer
you throw the switch, the switch closes and the brain
sends a serial data command on to the buss, called LIN buss
this goes to the hood brain, the TIPM, box.
this brain hears the command and executes it. by turning on
high power transistors drivers to flash 4 lamps. (and hazard does 4)
does hazards fail too, again, no inputs from you.
there is no fuse, nor any relay. no direct fuses like old days
but are fuses , 8,17,33 but this kills many other things.
its all 100% electronic, now. "magic" i fix this stuff for 50 years.
the TIPM has 4 outputs.
so you never told me both sides fail front and rear.
so cant help much,,,,
which of 4 lamps are dead, did you replace lamps that are dead first.
that be first if one fails. not attacking the TIPM
all 4 dead, , comm errors? scan it.
one side dead. be hard for that to happen. due to 4 drivers.b
but i dont have schematic of TIPM no body does, if i had it
id was 10x smarter even saying how to fix a TIPM.
I can. (but i know now to rev. engineer parts)
tell more get more
1: are all 4 corners dead?
2: just cluster , repeater lamps dead?
3: just hazards dead?
Mar 07, 2015 | Jeep Patriot Cars & Trucks
2008 honda accord air will not work ,has freon ,relay works but compressor will not kick on.
#1 top A/C post here ever. bravo that.
this is caused by by the AC brain.
(location varies by year, and country)
A/C brain discrete, cira 90s
to after 2007 , they moved the brain, now pure software inside
the ECU or BCM , on most cars.
it really dont matter much where it is until you get to back probe the bugger. right?
so , here is the reasons for A/C clutch dead.
1:clutch bad, apply 12v to it see if it works (wires discon, please)
do so for on 1second, so as not damage system.
check for coil ohms near 1ohm. at clutch.
infinity is bad coil.
OR do :
1b" 12v to coil AC on? any volt meter works. 11 to 15v typical.
13.3 to 14.7 running engine typical.
yes, clutch dead.
2: 12v not at coil of clutch bad relay.
3: relay coil not energized.
3a: power to relay not on coil, if yes, bad relay .
3b: relay coil dead. no power. the brain has it shut down!
4: the brain, stops the AC for all these reasons
simple answer , inputs wrong.
full answer:
a: too low freon pressure, in truth or sensor fibbing
b: too high freon pressure, same, reasons.
c: ENGINE over load, (pulling trailer or going WOT )
d: engine overheat. (ecu say so or AC has its own sensor saying so, RTM.
e: Evap core (the cold core in dash) has frozen over to a ice brick. (a freeze sensor is there) caused by stuck open expansion valve. in core.
f: no power to AC brain, 90s cars. or missing ground,
g: AC not on, or brain can not see fan going, usual the is just
the 12vdc to fan missing. or the wire fell off.
some cars have all this, my 96 does.
on newer cars the ECU can shut the AC down for many reasons.
most are related to safety to the driver, or Compressor.
for what reasons, only the FSM answers that , and varies
by year, engine type, model and country sold.
if in usa , you didnt say. then alldata dot com has these facts
and more , under section called HVAC.
The brain will not allow you to burn up the compressor or worse.
it tries very hard at that. even as old as 1991 cars. (some)
today all.
Oct 12, 2013 | 2008 Honda Accord 2.0i-VTEC
Got a 85 toyota pickup..will not start..replaced coil, brain box, and all fuses...still no fire from the coil?
Not sue what you mean by brain box. You may need to replace the ICM the Ignition Control Module that sits right below the coil. Mine cost almost $300 locally, but found them online for less then $100. When mine went out in my 1985 Toyota pickup I was doing about 45 MPH and it was just like someone turn the key off., dead, no spark nothing. I ran the troublesooting steps in my repair manual and found it was dead.
Sep 09, 2011 | 1985 Toyota Pickup
Model hp1702 power supply ok inverter ok but connect the lcd panel socket suddenly off's? the green indicator light ...
monitor old very very old. 13 years old in fact.
this is a CCFL back lamp old monitor
so is the back lamp dead, that it.
does a flash light pointed to the face show a working
front panel menu button OSD data now? this is first to do.
OSD is always first then check the backlamps for DEAD.
that green lamp actions are covered in the 1703 manual
did you read that ?
i guess you meant the green LED goes dead? suddenly>?
ill read it to you.
https://www.manualslib.com/manual/767564/Hp-L1702.html?page=44#manual
that is not some simple monitor no,
it has its own processor inside, and that needs power too.
it must convert VGA video RGB top LCD data., all non trivial.
page 7
Power Indicator: Green - Power On mode.
Amber - Power Saving mode.
Blank - Power Off Mode
so if it turns its self off
that means the Brain inside sees gross errors.
or the brain side lost power.
there are many tests.
in a pro show we check all power busses, if the black lamps work
the connect up i2c to the I2c port and scan it for errors
this is what we must do to see if the BRAIN inside sees gross errors.
there is no other ways. to do that.
or if connected the CCFL tubes the monitor turns off
well the CCFL tubes are shorted. and if are, then the brain
was correct to shut it off or risk a fire.
see? it really is very smart.
Aug 17, 2017 | HP L1702 17" LCD Monitor
The brain box is clicking and the car want crank.
THe brain box that is clicking is the dead battery or the dead alternator
Aug 29, 2009 | 2002 Ford Escort
Scanport GEM GL-821A/B 17" Flat Panel LCD Monitor Logo
105 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
