Question about Sony I/M CMT-CP1 98 FRENCH Shelf System
Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
My Sony shelf system has just developed a problem on the right hand speaker output, it makes a loud noise, humming, crackling sound even with the volume turned down. I've swapped speakers and it stays on the RH channel so I know the speaker is OK. Will take a look inside the rear and see if I can see anything obvious, has anyone got any suggestions on what it might be?
Thanks
  • Anonymous Jan 23, 2008
    I have a Sony DA90ESG the left speaker output has static. I moved the speaker to the right and it worked. I changed video input. It has something to do with the Internal Organs. Could anyone give me a idea what this would cost? OR tell me what to look for, as I have some low voltage experience. Thanks
  • rover57 Jan 23, 2008
    Thanks for your suggestion, have found that by flexing the main PCB where the speakers connect the problem can be made to disappear. Tried resoldering the connections but problem still exists, will look at soldered connections for the capacitors following your comments. Cheers
It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
Posted on Jan 23, 2008
Hi, I have a B&O beocenter 1800 with a really load hum on the right hand speaker. This occurs on both radio and turntable. I have swapped speakers and cables and hum stays with RHS speaker output
this old timer probably has an output amplifier fault.with a circuit diagram any competent engineer shoulb able to locate the problem with the turntable removed access is easy and so is replacing parts
Nov 19, 2013 | Bang and Olufsen Audio Players & Recorders
No sound in my Sony CMT EH15
Check the speaker wiring for possible stray wire shorts against one another on the back, if okay! suspect a bad audio output chip inside stereo.
Jul 19, 2012 | Sony CMTEH15 Audio Shelf System
My sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Check the back for speaker wire shorts, next! there may be a short in the audio output chip or surrounding parts in the stereo, this is more suited for a technician to sort out.
Jul 03, 2012 | Sony CMT-NEZ3 Shelf System
What is the wattage of the speakers in a Sony CMT-EX22?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-CMT-EX22-manual/id/268dj188/t/2/
Page 26-27. Something around 12 watts. Don
Apr 10, 2011 | Sony CMT-EX22 CD Shelf System
My Sony CMT-HP7 will not play any of my CDs. It says reading for a long time and then tells me that there is no CD and skips to the next CD... which it don't recognize.
Usually deleting the Upper and Lower Filters in the Registry resolves this issue. To do that follow this.
1. Run Regedit
2. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. Delete Upper and Lower Filters on the right hand side pane.
4. Exit and restart.
Please comment if the information has been helpful. Thank you and regards.
Aug 26, 2010 | Sony CMT-HP7 CD Shelf System
I have problem with my sony cmt-cp1 model. NO DISC
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 08, 2010 | Sony CMT-CP11 CD Shelf System
Speakers
You should be aware of the power output of the shelf system and at what ohms. Ex.--100watts @ 8 ohms. Which I think that is the rating of this unit. This means you will get 100 watts of power on the front left side and the front right side, if you hook up one 8 ohm speaker per side.
Apr 09, 2009 | Sony MHC-RX100AV Shelf System
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
CMT-BX5BT SONY spkrs aren't pulling in music (via BT) from laptop
I had the same problem. Here's the fix:
Control panel- Hardware & Sounds- Manage Audio Devices (under Sound)- Select Bluetooth Stereo Audio as default (right click- default) and Enjoy!
Dec 31, 2008 | Sony CMT-BX5BT Shelf System
276 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
