Panasonic PT-50DL54 50 in. Rear Projection HDTV-Ready Television
Problem for Panasonic PT-50DL54 50 in. Rear Projection HDTV-Ready...
Projection lamp timer reset
By hytec on Jan 21, 2008
Need instructions on how to reset the lamp timer on a panasonic pt-50dl54j tv.
Same Problem
Feb 05, 2009
-   how do you rest it already? -   Guest
Mar 03, 2008
-   Not a solution. There is no information on the reset in the service manual.
Very arrogant response.
As for simple instructions, there aren't any unless you pay the ridiculous price for the Panasonic bulb.-   Ned Limpopo
Best Solution
posted on Jun 10, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Turn your television on
Press volume down on the TV
Press the mute button on the remote
Green LED light on power button will flash
-timer now reset (no more warning light)
Solution #2
posted on Mar 01, 2008
Somewhat Helpful)
who BoB
Rank: Wiz
Rating: 82%, 63 votes
Well it is so easy if you know how to read simple instruction, I don't, when I said I do.
Click here hope that help you. http://service.panasonic.ca/pdp/ServiceManuals/pt50-60dl54-sm.pdf and go on page, Mmmm 28 and start reading, you'll understand after why you should respect technician, they read this over and over and over.
Oh this I mention your welcome, if you want to make me a faver, well I'll think of one.
What about Bob
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jun 26, 2009
Somewhat Helpful)
welcomejee
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 89%, 3220 votes
Thanks Who_BoB
Was this helpful?
Yes
No
Solution #4
posted on Feb 02, 2009
Somewhat Helpful)
rev20007
Rank: Apprentice
Rating: 75%, 1 votes
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Was this helpful?
Yes
No
Solution #5
posted on Nov 02, 2008
Not Rated)
invid8
Rank: Apprentice
Rating: 0%, 0 votes
my PT-50LC14 would not turn on. When you pressed the power button, it would change from a green light to off, then blink yellow twice every few seconds. I tried the "best solution" posted here that said to try to power on the TV and then press the Volume down button on the TV while pressing the Mute button on the Remote (that this would reset the lamp timer). I tried it and it worked. I pressed the power button knowing that it would just turn off but immediately started pressing the Volume down button on the TV several times will simultaneously pressing the Mute button ont the remote several times. The TV then slowly turned back on. Perhaps i need a new bulb but this bought me some time. Thanks!
Was this helpful?
Yes
No
Solution #6
posted on Oct 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Wow...
the "Best Solution" works! At least on my PT-50DL54 did it... :-)
Great,
Thanks a lot.
Solution #7
posted on Apr 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
manual says to consult instructions that came with lamp....
instructions say to consult owners manual....
PANASONIC SUCKS!!!
Popular Solutions for Panasonic PT-50DL54 50 in.
Questions and Unsolved Problems for Panasonic PT-50DL54 50 in.
Do you recommend Panasonic PT-50DL54 50 in. Rear Projection HDTV-Ready Television?
Answer
Answer
After replacing the lamp i get a flashing green light and no power up? Do I need to reset something... (More)
Answer
My panasonic dlp is only showing a lime green and sky blue coloring in pic. What is going on?
Answer
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly... (More)
Answer
I have a 50'' Panasonic LED monitor TV about 4 years old the past week it has had a green cast to... (More)
Answer
Where is the lamp/housing located and how do you get to it.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
