Question about Garmin StreetPilot C330 GPS Receiver
Low battery My refurbished Garmin worked fine until the battery ran low. It keeps cutting off in the car because the battery went dead.I hooked it up to the car with the accessory included but it keeps cutting off. It charges when I hook it up to my PC. What is my problem?
  • Kathy Myers
    Kathy Myers Jan 26, 2008
    Thank you, the car is new and the sockets, there are four of them are all fine. The adapter cord for my Garmin does not have a light, however, I noticed the unit itself was not making good contact with the adapter. I tightened it all up and it is working fine now. Thank you so much for your time and advice. The first comment I got was such a smart alecky reply from someone who had nothing better to do. Kathy
I had the same problem with mine shutting off ...turns out my battery was completely dead and the car charger just was not charging the unit. I charged it with the usb overnight and it worked fine:) I have yet to figure out if it is the car charger or the actual back piece the suctions to the window and attached to the battery but for now it works! Also another helpful hint for garmin C330 the Motorola Razor chargers work too I am using the house charger to charge it the wall:)
Posted on Oct 22, 2009
  • Garmin Master
  • 2,130 Answers
It sounds like the cigarette lighter charger/adapter isn't working.
1. First, does your cigarette lighter socket have +12VDC on it?
Try plugging in some other device that you know is good and see if the socket powers that device ok. If yes, read on below. If not, you probably have a blown fuse that powers the cigarette lighter socket. Use your vehicles owner manual to find where it is and how to replace it.
2. When you are using the Garmin cigarette lighter adapter, does the light come on the adapter? When the unit is powered by an external source (PC or Car) there should be a lightning bolt symbol that is shown over the battery bar graph display. Do you see the symbol? Try looking for the symbol when you connect it to the PC. You should also see it when using the car adapter. If not, the car adapter is defective. There is a fuse inside the Garmin car adapter plug that goes into the cigarette socket. Try looking to see if it's blown. If not, the adapter electronics is defective.
The reason why the unit keeps shutting off is because the battery isn't being charged.
Good Luck,
- Jim
Posted on Jan 23, 2008
    SHARCNET-USA Jan 25, 2008
    Thanks for the inappropiate vote. You never answerd any of my questions. I asked them so that I could help you find out what the problem was. There are a lot of people on here wanting to help and ask questions to better help understand what is causing the problem. Instead of answering my questions you gave me an inappropriate vote. Too bad. I wanted to help you.
Don't buy another
Posted on Jan 22, 2008
Battery keeps going flat
Check alternator voltage output, might be low. obd2 scanner
Jun 12, 2013 | Cars & Trucks
1998 pontiac sunfire manual. Car starts but sputters and then dies and is completly dead but in the morning will start again and then die. I changed the coil pack but still the same. what can it be?
You can't do any testing, until you have a battery
that will take and hold a charge
Then you move on to testing the Alternator,then
Fuel Pressure & continue on with other testing
Apr 04, 2013 | 1997 Pontiac Sunfire
New battery keeps going dead no low voltage light
Have the vehicle taken to one of many places that will test the Alternator output etc--narrow it down first without replacing that.
Voltage may drop enough to prevent starting without triggering the low voltage issue.
Jun 14, 2012 | 1997 Ford Escort
I have a Compaq CQ61-411 Notebook the battery went out the computer was working great but a message came up saying replace battery and it cut off and would not charge back up so it took me a few months to...
see your manuals and what the blink codes mean.
each PC has PDF manual that covers that.
blink codes are BIOS warnings.
to tell you what catastrophic failure happend
like low power
bad memory
processor dead
GPU dead.
and more, some have 12 errors possible (newer)
if the BIOS screens are dead, its lost power.
or one of the above.
Mar 20, 2017 | HP Compaq Presario CQ61410US Notebook
I have a 98' Grand Marquis with a 4.6 engine. as
have the alternator checked. if the alternator is not charging the vehicle is only supplied with what power is stored in the battery. once the battery is dead there is nothing to charge it
Jul 26, 2011 | 1998 Mercury Grand Marquis
The battery went dead when we left the lights on. Since then we have to put our radio code in every time we restart and the clock has to be reset. What can I do. Did not have this issue until the battery...
Have your battery tested. Have you had to jump start it each time? Whenever battery voltage goes low, it will require you to re enter that code. It could be that you have a weak battery, and during start up the voltage is going low enough to cut off keep alive memory in to your sound system. Again have the battery tested with a midtronics tester, or with a good quality carbon pile tester. GO TO A REPUTABLE GARAGE. Don't get the free test at auto zone. Those morons cause more harm than good. Most garages, at least around here (Green Bay) will test it for free, just because we might get to sell a battery, and actually make a buck in this crazy business! Good Luck
Feb 06, 2011 | 2004 Honda Odyssey
My garmin cannot start
Hi there... If you mean it doesn't do anything when you push/slide the on button, then try this... (mine did the same thing just yesterday and was a result of a very low battery - would not even start with 12v cord in from the car!)...
Find the USB cable that came with your Garmin. Hook the USB cable to your computer, with the other end hooking up to your Garmin (where the normal car cable goes).
The Garmin will probably turn on instantly once you have hooked it up to your PC (assuming the PC is turned on and in Windows etc). This will actually charge the Garmin battery too while hooked up the PC, so leave it connected for a little while (a couple of hours).
If it doesnt switch on automatically when connected to the PC, try using the slide ON switch. Once it is active, it will be in PC transfer mode (assuming you have an SD card in the card slot of the Garmin). Now is a good time to use the Garmin WebUpdate application (available from to see if any software updates are available for your unit. If so, go ahead and install them. I updated mine yesterday!
Once you get it working via connection to the PC and the battery has charged up a little, take it back to the car and keep the 12v car cable plugged in all the time. This will continue to charge it up as it is being used (while the car is running of course). You should find that after u get it working on the PC it will again work in the car too...
i think it just turns it off for some reason permanently when it gets a really low/dead battery and only the PC hookup seems to re-activate it... Also, apparently you can hold the slide switch on the Garmin in the ON position for 7 seconds to reset the unit, but that didn't work for me... Worth a try anyway!
Jan 16, 2009 | Garmin nuvi 260W GPS Receiver
Problem with battery or battery connection or alternator
sounds like the altenator or voltage regulator
Jul 09, 2008 | 1993 Ford Tempo
Garmin c530 Streetpilot
I just called tech support at 1-800-800-1020 and I was told that the battery on the unit may be so low that it won't power on even with a power source. The unit actually uses more power than it's taking in from the car charger. I was told to plug it into the computer using the USB cable and give it a few hours to replenish the battery. Apparently it should be plugged into the computer ever so often to keep the battery from getting too low.
May 09, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
744 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
