Question about Boxlight CP 10t Multimedia Projector
Shadowing on a Boxlight 6000E
As the title says really.
The shadow is to the left of the main image.
It is not any particular colour and remains if I disconnect the LCD panels one at a time.
The shadow is an any projected image, including menus, so I assume it's not coming from the PC.
Cheers
Paul
  • 2,237 Answers
Look at the diffuser lenses just after the lamp. there should be 2. the second one tends to have burn spots after a while in dusty and hot conditions. if the lens is ok, look at the lcds with the light on. do you see shadows on the panels? if so, you have a main board issue. if not, you have a misaligned mirror.
Posted on Jan 27, 2010
I am experiencing some "shadowing" when I print a document
The problem most like resides in the ETB or electronic transfer belt....The image is not being removed from the belt to the paper causing shadowing effect...you need to replace the ETB. Try www.getthatpart.com they have great units at great prices and have someone on the phone you can talk to. If you feel its not the ETB and you don't see any toner left on the belt call these guys up and they can help you futher
Oct 25, 2010 | HP Color LaserJet 2600n Printer
Hi i have a Philips 4331 LCD projector its giving me double image which is not well colour mixed i have tryed to clean all the LCD pannel and all the lance but problem is still the same, if you have any...
If you are having "shadowing", this indicates a convergence problem in the LCD optical engine. Convergence is the correct alignment of all panels so there is no shadowing, or at worst limited to a one pixel shift. Some models can be adjusted, others cannot depending on the optical engine.
Aug 14, 2010 | Philips cBright XG1 Multimedia Projector
Color shadowing on white lettering
This is called convergence.
If the TV has auto convergence or 'Flash Focus', run it. All projection TVs have customer controls for minor adjustment. Give it a go with the menu or the remote convergence controls.
If not, this is a common adjustment made by a technician on a house call.
If the error is really big, say the colours are curved or you can see clear separate letters and things, you will need the convergence repaired. Get a quote - Usually about $300- $600 in home service.
Mar 29, 2010 | Televison & Video
Grey bands and shadowing
Uninstall the video driver from the Computer, restart the Computer then reinstall it. Furthermore, check for any updates for the video drivers.
You may also connect the monitor to any other normally functioning Computer to check if the lines remain there.
If it's so then the monitor requires servicing.
Nov 07, 2009 | Samsung SyncMaster 244T Monitor
Shadowing on lower right of screen on InFocus LP70+
the light tunnel (like a square tube of mirrors) is collapsing. it needs to be replaced, but it's a bit involved, so and infocus service center would be your best bet. if you wish to try it yourself, let me know.
Jul 14, 2009 | InFocus LP70+ Multimedia Projector
53UWX10BQ - DOUBLE IMAGING OR SHADOWING
Good Day, sh28;
Sounds like bad convergence IC’s, chips. Hit recommends using STK392-150’s and replacing the bias resistors.
Good Luck, Big Irish.
Jun 23, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
2.5 amp fuse blows
Hi there!
The set is rather old. I would suggest checking the PTC. Located close to the mains on/off switch.(cream in colour) This will fail with age. Also change suspicious looking caps. As for the shadowing, I am not sure what it looks like, but it may be related to the same problem. Good Luck, Regards, JUS004
Mar 24, 2008 | Pioneer SD-P62A5-K TV
DVD player producing poor colour image
Go purchase a DVD player cleaner. It will look somewhat like a DVD/CD and will clean the read heads. Often the issues is dirt/dust.
Semper Fi,
Z
Jan 29, 2018 | Televison & Video
Boxlight CP 10t Multimedia Projector Logo
156 people viewed this question
Top Boxlight Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
