DISPLAY INTERMITTENT THE DISPLAY DID NOT COME ON WHEN I ACTIVATED THE ON BUTTON. REPEATEDLY SWITCHING ON AND OFF MADE NO DIFFERENCE. LEFT OFF FOR A FEW DAYS AND THEN SWITCHED ON AND DISPLAY CAME ON AS NORMAL. NEXT DAY SWITCHED ON AND NOTHING ON THE DISPLAY. NEXT DAY OK AGAIN. DURING ALL THIS 'NO DISPLAY' COMPUTER LOADS OK, I JUST CAN'T SEE ANYTHING! I HAVE CHECKED CONNECTIONS: HARD DRIVE, SCREEN ETC BUT CANNOT FIND A PROBLEM. CAN YOU TELL ME WHERE THE MEMORY CHIPS ARE LOCATED, I COULD CHECK THESE. I AM LEAVING THE COMPUTER PERMANENTLY ON SO THAT HOPEFULLY I CAN USE IT. ANY SUGGESTIONS. WHEN ON THE LAPTOP WORKS PERFECTLY. IT REMAINS IN THE SAME PLACE ALL THE TIME, I USE IT AS A DESKTOP. THANKS MIKE
  • Dietze Mar 01, 2008
    I have the same problem with my Joybook 5000 and it seems to be impossible to get a new inverter over here in Germany.
    Can somebody help?
    Karl
  • gayaimran Jan 07, 2009
    I have Inspiron 1721 laptop when you press start button screen display in half and in that half screen there is thick line in the center is there any way you can solve this problem or look for the replacement
    Genius:
  • 1,601 Answers
Mike, The problem with your laptop is the inverter board. This part changes the DC to AC to power the backlight.
Please list the manufacturer and model of your laptop and I will look up your memory location.
thanks
Posted on Jan 21, 2008
Miele w1913 simulation active on display when I press start/stop
Press and hold the Start/Stop button while switching the unit on with the On/Off switch.
As soon as the Start/Stop illumination ring lights constantly, after approx. 5 sec., release the Start/Stop button.
Immediately press and hold the Start/Stop button until the Demo-Mode is activated, approx. 4 seconds.
Demo-Program deactivation: Follow the instruction for Demo-Mode access above.
Aug 16, 2014 | Washing Machines
How do you enter the code on a Grundig SC303 car radio Serial no GM0303R2400691
Grundig SC303 Vauxhall Code Entry
After switching on the set the display will show ' 1 ' as the first digit, this can only be changed to either ' 1 ' or ' 0 '.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
To save the code press and hold the ' AS ' key for a few seconds.
The set should now operate.
May 06, 2011 | Car Audio & Video
How do I reset the compuer after oil change?
SWITCH THE IGNITION ON ENGINE OFF.REPEATEDLY PRESS SMALL BUTTON UNDER LOWER RIGHT SPEEDOMETER UNTIL OIL LIFE IS DISPLAYED.THEN PRESS AND HOLD THE SAME BUTTON FOR 10 SECONDS UNTIL THE REMAINING ENGINE OIL LIFE RESET MODE IS DISPLAYED.RESET PROCEDURE MUST BE CARRIED OUT WITHIN 30 SECONDS. PRESS SMALL BUTTON LOWER LEFT TACHOMETER TO DISPLAY RESET TO CONFIRM RESET PRESS SMALL BUTTON UNDER RIGHT SPEEDOMETER. TO CANCEL RESET PRESS SMALL BUTTON LOWER LEFT TACHOMETER TO DISPLAY CANCEL THEN PRESS SMALL BUTTON LOWER RIGHT SPEEDOMETER.THEN SWITCH IGNITION OFF.
Mar 01, 2011 | 2008 Acura TSX
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have the 4 digit code to unlock my 1997 Monte Carlo radio, however I don't remember the sequence to unlock it.
Becker
After switching on the unit the display shows 'CODE'
Press preset [ 4 ] repeatedly for the third digit
Followed by pressing [AUTOMATIC] button to enter.
Oct 09, 2010 | Car Audio & Video
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
My kenwood 5016 wont take my code mind u i dont no what botton 2 push as have no book on how it works
Kenwood KDC 5016 Code Entry
After switching on the unit the display will show 'ENTER' followed by 'CODE - - - -'
Followed by pressing [DISP/NAMES] button to enter.
The radio will display 'ALL OFF' once the code is entered.
Press [SRC] button to switch on.
The set will now operate.
Nov 10, 2009 | Kenwood Car Audio & Video
Displays 104 when it is 65 control is whacky'is it sensor or thermostat, or what
Try this test for codes
Electronic Automatic Temperature Control Module Self-Test
  • The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
  • The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
  • To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
  • To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF).
  • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Jul 30, 2009 | 2002 Mercury Grand Marquis
Setting the time on car stereo/cd player
Changing the general settings
(PSM)
You can change the items listed on the next page
by using the PSM (Preferred Setting Mode) control.
• The PSM items are grouped into five
categories—“Disp (display),” “Clock,” “Tuner,”
“Color,” and “Audio.”
Basic Procedure
1 Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display.
(See page 23.)
The currently selected
category is shown on the
left side of the display.
2 Press 5 (up) or ∞ (down) repeatedly
until your desired PSM category
appears on the left side of the
display.
3 Select the PSM item you want to
adjust.
4 Adjust the PSM item selected.
5 Repeat steps 2 to 4 to adjust the other
PSM items if necessary.
6 Finish the setting.
To set clock—Clock Hr, Clock Min
You can set the clock using the PSM control.
1 Press and hold SEL (select) for more than 2
seconds so that one of the PSM items appears
on the display.
2 Press 5 or ∞ repeatedly until “Clock” is selected
as the PSM category (it is shown on the left side
of the display).
3 Press ¢ or 4 to select “Clock Hr
(hour).”
4 Turn the control dial to adjust the hour.
5 Press ¢ or 4 to select “Clock Min
(minute).”
6 Turn the control dial to adjust the minute.
Nov 04, 2008 | JVC KD-G720 CD Player
Eypad problem
First try repeatedly pressing 8 key while at Home screen to see if problem is permanent or intermittent.
Pressing a number key at Home screen will cause the phone to display 8 if any press is recoginized/dialing.
If it is intermittent, then it is likely a hardware problem. Disassemble phone to keypad/phone printed circuit interface. Clean interface with alcohol or clean pencil eraser and disconnect/reconnect any cable interfaces. This may be worth a try even if key is not intermittent.
If this doesn't work or you don't want to disassemble, you can try a phone Hard Reset. See my other solutions on how to do a Hard Reset. Basically, hold down both left and right softkeys while turning on the phone. A Reset screen will display. Note all personal apps and data you added to phone since new is lost.
May 04, 2008 | Orange SPV C500 Pocket PC
Computers & Internet Logo
187 people viewed this question
Alun Cox
David Payne
David Payne
