Question about Honeywell QuietCare HCM-630 Humidifier
Dog chewed up the filter cage
Me dog chewed on the HCM630 screw-in ball filter cage. You think I can I get a new one?
  • 123 Answers
You can order a new cap, but you won't be able to get one with the filter ball. Every site i went to says they are unavaliable.
If you are interested in just buying the cap, here is the link:
http://www.humidifierfilters.com/parts4models.php?brand=honeywell&model=hcm630
Good Luck.
Posted on Apr 21, 2008
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
I have a basement dehumifiier and I think there should be a way to clean the filter but don't know how to go about it?
you can unplug the unit,then remove top cover rear screw,then 6 screws on side of front grille,then all screws around the rest of the units wrap around cover,being careful to not stress any wires in doing so,then carefully blow out inside components out with low pressure compressed air or a vacuum cleaner
Mar 25, 2011 | Whirlpool AD50USR 50 Pint Per Day Ultra...
Dehumidifier not collecting water
do the lines from the compressor to the evaporator freeze up or ice up anywhere,if so it could be low on refrigerant,also check the start capacitor in the compressor power circuit,if its bad the compressor won't run
Apr 04, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Humidifier causing sump pump to cycle repetativley
I'm assuming this unit has a reservoir installed in the heat duct and has a rotating pad in a wire cage -- is this correct?
If so, it sounds as if the float valve in the humidifier reservoir is out of adjustment or the valve is leaking, The reservoir is overfilling and running into the sump.
There is an adjustment on the float, if lowering the float does not solve the problem, the valve is leaking -- it'll probably need replacing.
May 05, 2009 | Aprilaire 700 Humidifier
Honeywell 6013i new machine will light up but will not work
Unplug the unit (safety first), remove the two water jugs at the back lay them down. Find a tray large enough to fit the motor and filter inside of it put it next to the unit. Lift off the motor and set it next to the tray, lift out the filter and set it into the tray (in might be wet, and we wouldn't want a mess). Look for a small plastic tower in the base, inside that tower is supposed to be a float with a screw threaded into the top. If there is no screw, grab a small one that is about 5/8" long and screw it in about 1/4" put the filter and motor on, verify that the motor is sitting evenly on the base. If it isn't, turn the screw colckwise 1 full turn and recheck the motor/base fit. When it looks even, put the motor back on, plug it in and hope for the best!!
Take your time and don't forget that this is not a precision machine, so some 'adjustments' are necessary
Nov 24, 2008 | Honeywell QuietCare HCM-6013i Humidifier
FURNACE RUNNING LOUD
sounds like either the motor is off balance
or is going bad again
either way id be on the phone to the guy who did the rapair
more than likely the set screw on the sqiral cage came loose and now its vibrating
Nov 11, 2008 | Aprilaire 700 Humidifier
Missing part
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is a link to the manual for the humidifier you bought.
It shows how everything comes apart and how it all goes together with the filter.
Hope this helps.
Good Luck.
Apr 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Filter changing
I had the manual..phamplet and didn
t know I had it It was attached to the bill.........it's so small, you don't think it's anything..but it's the manual!
Mar 06, 2008 | Bionaire BCM7204-U 3 Gallon Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Honeywell QuietCare HCM-630 Humidifier Logo
187 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
