Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wd61 my machine was switch on and the RCD blew and now the machine will not run, there is no power light, checked plug, fuse, and run a pat test on it and found no wiring faults, cold this be , Switch. or Controller. Cheer Dave
  • 139 Answers
What ha happend is the door interlock shorted and blew the rcd. However in doing so it al blew a triac on the timer..
This is very easy to repair if you know how to get to the timer... but you also have to replace the door inter lock...
Solder a bit of wire between the connections on the timer...
If you follow the neutral wire back fro mthe door interlock upto the timer then you will see what i mean by it blowing the triac...
Posted on Jan 21, 2008
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
Our hotpoint ctd40 condenser dryer aquarius trips our household rcd panel when you try to start the machine all the power lights are on and it does not blow the plug fuse. I have cleaned all the filters...
I would get an electrician to check the machine as it appears to have an earth fault on the machine wiring , This type of fault will operate the RCD quicker than the fuse will operate. I am a qualified electrician by trade.
Feb 04, 2011 | Hotpoint Dryers
Hotpoint WD61. Door lock light went out before drum stopped after spin prog, now can't get anything to work. I think the Door micro switch or plug fuse... Can you think of anything else to check? How do I...
hi you need to take off the clip thats around the seal ..pull seal away....the switch is held in with two scews ************** TURN APPLIANCE OFF AT WALL PULL PLUG OUT ************** undo scews take interlock out and replace.hope this helps.01179512835
Dec 30, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Machine partially fills and then stops working.
THE RCD SWITCH is concealed on the inner side of the hindges of the door or on the top innerside of the door. it is a simple push switch which has a mechanism of push to on/off
this switch has got stuck in off position.
change this switch or spray a drop of rust removal oil. it will start functioning
Aug 27, 2009 | Whirlpool AWM8123 Front Load Washer
Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
Feb 07, 2009 | Hotpoint Dryers
Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Sep 20, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
171 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
