Question about Fisher Price Deluxe Perfect Support Baby Carrier
Car Seat - unable to assemble correctly.
Hi, we recently removed our child's car seat to clean it (she had spilt milk all over it). Anyway, we washed it all out and tried to put it back together again but we can't. The straps that are supposed to go over her torso are too short and we don't know how to extend them. We have tried everything and had a few people take a look at it to no avail - please help.
  • Anonymous Mar 22, 2014
    i took straps out to wash seat cover, where do straps attach under seat?
    Problem Solver:
  • 11 Answers
Hi houdza,
i am an engineer in honda company in japan.they would have got shrunk so better buy a new one.
Posted on May 31, 2008
In order to change from the toddler seat to the booster for a child over 40 lbs, what do I do?? does the seat just become attached to the car by the seat belt? does it need to be attached by other...
please feel free to call at 1-800-544-1108 and they can send you a manual in case you dont have it.
*To convert the car seat into a booster seat, turn the car seat over and remove the pin that holds the base in place. tHEN REMOVE THE BELTS AND THE BUCKLE.
*To remove you need to bend/twist the keeper until you can push it UP through the seat and remove the belt/strap. It is now a booster seat for use with a lap/shoulder belt in the car. Store all the parts you removed in a ziploc bag for when your child outgrows it so it can be reused
PLEASE RATE MY HELP :)
Sep 17, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How do I remove the back seat of my 2009 pontiac vibe? I spilt milk and it went down between the seats and I know it will smell if I don;t get it cleaned properly.
move front seats forward.grasp seat cushion under front[where your heels would be if seated] and lift to release seat from 'clips' underneath.pull seat towards you to remove.push it back in firmly before pushing down to 're-clip'.
Oct 11, 2009 | 2009 Pontiac Vibe
Can't get the armrests off to clean the cover
You CAN remove the armrests- quite easily actually! All you need to do is grab a small pair of pliers. Behind each armrest are two tabs. With the pliers, pull the bottom tab out. Slide the top tab underneath the bottom. The armrest will pop right off! Which means you can wash the pad seat and all!
Sep 22, 2009 | Evenflo Generations
Child car seat - unable to put it back together after washing
You need to pass the belt behind the sit.
Mar 21, 2009 | Baby Gear
I need to put the straps back in seat
When I was doing research on your problem, I came across this recall. Please read and see if it relates to your product. RECALL ID# 66785 - CHILD SEAT Recall Date: July 28, 1993 Model Affected: AUTOMATE Recall Summary: THE TONGUE OF THE BUCKLE ASSEMBLY CAN CORRODE. THIS DOES NOT COMPLY WITH FMVSS 213, "CHILD RESTRAINT SYSTEMS." ALSO, THE LABEL WITH USE AND SAFETY INSTRUCTIONS IS MISSING FROM THE PLAYSKOOL MODEL. Consequences: BUCKLE ASSEMBLY CORROSION COULD AFFECT THE SAFETYPERFORMANCE OF THE CHILD RESTRAINT. THE MISSING LABEL MAY CAUSE IMPROPER USEOF THE CHILD SAFETY SEAT. Remedy: KOLCRAFT WILL PROVIDE OWNERS WITH A FREE REPLACEMENT HARNESS ASSEMBLY AND INSTALLATION INSTRUCTIONS. OWNERS OF THE AFFECTED CHILD SEATS SHOULD CALL KOLCRAFT TOLL-FREE AT 1-800-453-7673, TO OBTAIN A NEW REPLACEMENT HARNESS ASSEMBLY. Notes: KOLCRAFT ENTERPRISES, INC. Potential Car Seats Affected: 307017
Dec 29, 2008 | Kolcraft Universal 46250L-N
I need this car seat manual bad!!!!
if you have a 22260 car seat is easy
1, on the base of the seat there is a push down clip that you need to push down and remove the steel bar of by sliding it out
2 unclip the seat strap for the seat by removing the brass "Y" on the back .PAY ATTENTION ON HOW YOU REMOVE THE STRAP IS ALL ONE PICE AND YOU NEED TO LOOP IT FROM ONE SIDE TO THE OTHERE
3. on the back of the seat there is 2 screws that you need to remove. the you remove the adj. back.
4. remove the cover and wash you can place it in the dryer or hand out to dry
5. instill the same way you removed
good luck
Aug 04, 2008 | Baby Gear
Need help
https://plweb.evenflo.com/faq_detail.aspx?faqid=4990 Question: How do I care and clean for my PortAbout 3/PortAbout V infant car seat? Answer: To clean pad slide the elastic loops of the seat pad off of the seat shell. Remove the harness system. Cloth pad, canopy, and head support may be machine washed separately cold water, delicate cycle, tumble dry 10-15 minutes, low heat. Wipe straps, buckles, and harness adjusters with warm damp cloth and mild soap. Air dry. NOTE: DO NOT submerge harness assembly in water. To help protect the vehicle upholstery, place a towel beneath and behind the child restraint.
Feb 23, 2007 | Evenflo PortAbout 5 Infant
Fisher Price Deluxe Perfect Support Baby Carrier Logo
277 people viewed this question
Top Fisher Price Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
