Question about Speed Queen AWS52NW Top Load Washer
Water running out from under the washer
Sometimes when my washer spins water runs out from under it and it makes anoise in the kitchen sink drains, and last night the water started coming up in the drain, is something wrong with my washer or is it the lines under the house?
  • cowher Jul 17, 2008
    Sometimes when my washer spins water runs out from under it.
  • 164 Answers
Sounds like two seperate problems. firsst water running from under your machine might be a bad seal, or water could be backing up the drain line. i would guess that it is a plumbing problem because of theissue with water in the sink. have a plumber snake out the drain lines and the problem with the washer should disappear.
Posted on Jan 22, 2008
What would cause a gurgling sound at the kitchen sink when no water is running anywhere in the house?
the waste disposal system for your house was installed by a person who was not competent to do the job and didn't make allowances for sufficient air pipes in the system or placed them on the wrong side of the traps
I would have an engineer inspect the installation to pin point the problem so that what you have doesn't occur and if it is installed contrary to plan and engineering requirements seek legal redress from the plumber that did the job
Nov 15, 2015 | Dishwashers
Dish washer water is clogged up
sounds like the pump is running but clogged. You might want to 1-remove as much water as possible by cupping it out manually,2- turn the breaker off and ensure no power, 3- take off bottom cover, 4-locate drain line (it will go into cabinet under kitchen sink-hooked up to sink line more than likely) and take off pump on dishwasher end and take off sink. you can remove the hose and see if and where clog is located.Grease is sometimes a culprit or other bits and pieces of food build up. You should also investigate the area where the drain line hooks into the unit and ensure that is clear. reconnect hose under sink and fish thru hole in side of cabinet to back of dishwasher. someone else or you can then reach under dishwasher to reconnect line to dishwasher. make sure drain is hose is connected properly at both ends! You'll probably need a phillips head screwdriver, 1/4" nutdriver and a pair of pliers
Jan 15, 2013 | Dishwashers
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Why won't my washer won't spin or drain
If the water is not removed first, the spin will not occur. Do you hear the pump run when it starts the spin cycle? If nothing, the pump may be jammed with debris, or the motor itself may have failed. If the motor runs, but no water comes out of the drain, then look for a kinked drain hose (inside the cabinet) or possibly a stray sock lodged in the drain outlet under the outer tub. Sometimes the pump impeller will come loose from the motor shaft causing loss of pump action. Hope that some of this helps!
Apr 06, 2010 | Tecnik TKL9260 Front Load Washer
My stainless steel dishwasher smells
You need to check to see if the drain line runs from the dishwasher pump to either a "T" on your kitchen sink drain or if it connects directly to the garbage disposal. Either connection is okay. However, water can run downhill from either connection to your dishwasher. To prevent dirty water from your sink or garbage disposal from running downhill to the dishwasher, you may have to install a dishwasher air gap. This can be purchased at a appliance parts store or a home improvement store like a Home Depot or Lowes. It is a "Y" shaped device that should be installed above the dishwasher drain line connection under the sink. As water will not run up hill, you need to make sure that the Air Gap is installed higher than the drain line's connection under the sink. "The Air Gap device should be mounted as high as you can under the sink."
Aug 22, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
After washing dishes in the kitchen sink, water fills up and stands in the dishwasher and drains only after running the dishwasher
Hi, There is a drain hose under the sink that goes to the dishwasher. Make sure that hose is raised up higher then the drain pipe for you sink. It is just draining into the dishwasher because the drain hose is to low.
I hope this helps you. Please let me know if I can assist you further.
Jul 10, 2009 | Maytag Dishwasher
No water coming in after sink blockage
Sounds simple , but the plumber may have shut the dishwasher water off. Valve is probably under the sink or near the machine in the basement or crawl space. Good luck.
Jul 04, 2009 | Asko 1385 Dishwasher
Blocked sink maybe equalls non spin or drain of washer
It depends on where the sink is blocked, and how the washing machine plumbing is set up.
If the sink is blocked in the p-trap under the sink, and the washing machine does not drain to that trap, then it's a separate problem.
That being said, if this is in fact the way the washing machine is plumbed, then it indicates that there is not an air gap between the washing machine hose and the drain. There must be an air gap or the washer will likely not drain, regardless of how it is plumbed to the sink or not.
Reply back with further information, or if you need clarification. But yes, the sink being plugged could be the cause of the washer problem, or may just be coincidental and not have anything to do with it.
Feb 03, 2009 | Indesit W 123 Front Load Washer
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Speed Queen AWS52NW Top Load Washer Logo
158 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
