Question about Xerox Phaser 8400 Laser Printer
Work center 220 xerox
How to reset 220 multi function's counter
    President:
  • 2,072 Answers
Either remove or short out the NVM battery.
That should reset it.
Posted on Jan 22, 2008
Machine error 46
Error 46 means one or both of the ink purging (happens each time the printer cleans itself) counters have exceeded the maximum level. This is supposed to require new ink absorber boxes/pads to be fitted to the machine, but there is a way around this.
If you search YouTube for your printer model, you will find videos on how to reset these counters. You run the risk of the waste ink overflowing, but this is very rare.
Dec 29, 2013 | Brother Multi-Function Center® MFC-215C...
46 keeps displaying we tried a trouble shooting idea,, pressing 80 ... but we cant press anything
Replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Read here how to purge counter to zerp
May 24, 2011 | Brother Multi-Function Center MFC-240C...
Wont copy, displays 09,038,46: 14444
www.support.xerox.com/go/results.asp?...8560MFP...
This is a fault of the inkloader. A broken ink is not tripping the sensor, or it is out of ink.
Turn on printer. When logo starts, press and hold the info and back buttons until it says entering diags.
Go to functions menu, scroll to reset IRC counter,enter, and then exit diags. Printer will boot to ready.
Well when the logo is moving before it centers is when you hold down the back and help buttons and it should reboot in service mode, usually it takes it a second or two to start the process. So you can try that again or go into service mode the way you did before. Once in the service/diagnostic mode you need to scroll to the bottom to the function menu then reset the IRC counter in the sub menu and you should be good to go. You were almost there before. I have to do one today so if I notice anything different than the instructions given to you I will post back but Ive done it several times and everything sounds right.
Master link below. http://webcache.googleusercontent.com/search?q=cache:RP4PhFss0oMJ:www.fixyourownprinter.com/forums/printer/62877+Xerox+Phaser+8560MFP/D+error+09,038,46:+14444&cd=5&hl=en&ct=clnk&gl=nz
Jun 10, 2010 | Xerox Phaser 8560MFP Laser Printer
Brother all in one 5440cn say unable to clean see trouble shooting and routine maintance
May be it's waste ink counter is full.Try this:
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Sep 29, 2009 | Brother Multi-Function Center MFC-240C...
Have just replaced ink soakage unit MFC425CN
After replacement you need to go into diagnostics and reset the counter. I am not allowed to give that info. but your not done until you reset the counter.
Aug 11, 2009 | Brother MFC-425CN Multi-Function Center...
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
Wana to reset counter of p220workcenter xerox
Remove or quickly short out the NVM battery, That should reset it.
Jan 21, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
104 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
