Question about Xerox Phaser 8400 Laser Printer
Wana to reset counter of p220workcenter xerox
Can u help
for p220wrk center xerox .
hoping faver
  • 2,072 Answers
Remove or quickly short out the NVM battery, That should reset it.
Posted on Jan 22, 2008
How do I fix a fuser error in a Xerox Work Center 4250 printer?
Hello, my name is Steve.
Keep in-mind that you still need to "Reset" the fuser's Image count.
Resetting this will start the process from "0".
Hope this helps,Steve
Aug 18, 2015 | Xerox Office Equipment & Supplies
How to reset xerox m118 drum
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
How do I reset 2nd bias transfer roll for xerox 7556
On the 7556 and most other Xerox copiers, follow these steps to reset the counter. You do NOT need to call out a tech.
The supply life counters must be reset when some supplies are replaced.
  1. Log in as the System Administrator or Key Operator.
  2. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
  3. Select the [Tools] tab on the Touch Screen.
  4. Select the [Device Settings] button.
  5. Select [Supplies], and then under Features select [Supply Counter Reset].
  6. Select the required supply item, and then select [Reset Counter].
  7. Select [Reset] when the confirmation screen is displayed.
  8. Select [Close].
  9. Press the [Log In / Out] button on the Control Panel. The Logout screen will be displayed.
  10. Select the [Logout] button on the Touch Screen to exit.
Feb 11, 2013 | Xerox DocuColor 3535 Copier
Xerox ws m24 drum counter reset?
how we can reset counter of drum unit m24
Nov 20, 2010 | Xerox WorkCentre M-24 Color Copier
I change Drum On work center pro 555 Fax Be cause it told me it was low but i cant clear the warning message off the fax i shut dowbn and rebutted but nothing can you help
Drum units usually have an electronic counter that have to be reset through a sequence of key strokes on the number pad. Your local dealership should be able to give you the info to clear the drum counter
Oct 17, 2009 | Xerox Office Equipment & Supplies
The maint kit resets the counter when it is installed. You may have gotten a bad maint kit or the black plasstic part that the roller slides into is bad. That is where the connection is to reset the counter.
Mar 18, 2009 | Xerox Phaser 8560MFP Laser Printer
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
Work center 220 xerox
Either remove or short out the NVM battery.
Jan 21, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
80 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
