Question about Samsung SF-340 Plain Paper Inkjet Fax
Toner cartridge needs changing!
I am new to the office, fax machine has gone down and I cant find the manual anybody know how to change the toner - any one possess a manual?
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,362 Answers
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
How do I open the machine to change the toner cartridge?
You just pull down the front cover that is just below where the copies come out of the machine. You will see the toner cartridge. It has a small "handle" on it. It just pulls out the front of the machine. Then just unpack the new one making sure to remove the seal tape if it is installed on your new toner. Then re-install the new cartridge and close the door. If you have your users manual for the machine, the instructions are in the manual. If you are using a OEM Canon toner cartridge I believe the instructions are included in the box.
Good Luck and Thank You for using Fixya.
Dec 28, 2010 | Canon FAXPHONE L170 Plain Paper Laser
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
I have a samsuns SF515 fax machine after changing the toner cartridge the message still appears "toner Empty" I have tried several new cartridges with the same issue.
if you have changed the drum/toner unit then the machine should have a fuse on top of the drum unit.I have come across some cartridges that don't have them on the unit.The fuse resets the fax so that it knows there is a new unit installed.If that does work then clear the machines memory using the control panel
Jun 14, 2010 | Samsung SF-515 Plain Paper Laser Fax
The scree reads change drum soon. what does it mean
The drum is the part of the unit that actually does the transfer of the toner onto the paper. Each toner cartridge does about 2,000 pages and the drum needs to be replaced with the ~6th toner cartridge change (varies with use). Order part DR-250 from Brother or any office supply place that would carry the part.
To replace (wait until print quality decreases or it reads change drum now and stops working). Turn off the unit and let it cool. Close the document tray and the extension and open the top cover. Remove the drum carefully and place it where the toner will not spill. Remove the toner cartridge (if it is still good) and set it aside to put in the new drum.
Wrap the old cartridge up and dispose of properly (not in the domestic trash). Keep the new drum out of the light (keep it sealed until needed) as much as possible. Insert the toner cartridge in the new drum. Then insert the unit into the Fax machine. (Hold by the handles) Close the top cover and the starter sheet should be ejected by the machine.
I hope this helps.
May 03, 2010 | Brother IntelliFAX 2800 Laser Fax
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Replaced toner alarm light is still on saying replace toner
The toner has a fuse in it. When you replace the toner the fuse blows and resets the toner counter/light. Sometimes it blows and fails to reset. If you can solider you can replace the fuse and try again. Otherwise you will have to exchange the toner cartridge for a new one.
Jul 03, 2009 | Muratec F-300 Fax
Rotating toner cartridges to change
Every time you open and closes the door cover the toners rotate,open and close it untill she can see the black cartridge.
Apr 08, 2009 | Canon Office Equipment & Supplies
Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner
most likely its a defective toner unit, they have a chip on them that tells the machine when it was installed, and how much life it has remaining. if the machine doesn't recognise that its a new toner cartridge its probably a defecive unit. you should return the cartridge from where you got it and try another.
Jun 08, 2008 | Brother IntelliFax-2820 Laser Fax
Samsung SF-340 Plain Paper Inkjet Fax Logo
159 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
