Washer stopped during rinse cycle. Power button will not turn off and it is the only light that works. I think my wife used soap that was not HE
Sounds like a control or door lock problem. Try resetting you ccu ( computer control) by unplugging the unit for 30 minutes first. If this does not work then you probably have a bad door latch or bad ccu. You should have a technician do this repair. The wrong soap will not cause this problem, although it can eventually cause other problems. Good Luck, Appliance Specialists
