The Eee PC 1101HA netbook with a 11.6-inch display. For this and its
characteristics could be defined almost a notebook. Obviously, a
larger than normal netbook weighs more, but the Asus Eee PC 1101HA is a
netbook with mobile calling. Asus Eee PC 1101HA promises up to eleven
hours of
PA3420U-1BRS battery life, thanks to the Intel
Atom Z520 chip.
Homes and Design
The Eee PC 1101HA has the same form "shell" 1008HA Asus Eee PC. The
case is polished and its shape makes it particularly elegant netbook.
We noted that despite the gloss paint handprints not remain imprinted
on the case easily. This
Asus Eee PC
1000H is available in white pearl, black and pink crystal.
The hinges Eee PC 1101 HA self-locking (no mechanical locking) but
well hoods that limits the opening angle to a maximum of 130 degrees,
this makes little netbook fittings for use legs. The screen however is
quite stable.
Autonomy
Asus EeePC 1101 declares that HA is able to provide even eleven hours
of
VGP-BPS2C
battery life. Indeed, the netbook can reach eleven hours, but with
the six-cell
DV1000 Battery and without Wi-Fi active since our
test Eee PC 1101 HA has worked from time to time reaching autonomy of
10, 48 hours. The test was performed with a non-intensive use and
without wireless enabled. With wireless enabled netbook's
Inspiron XPS
M1710 battery life decreases by about three hours.
Weight and Dimensions
The amp 11.6-inch display makes the netbook a bit 'pesantino (1.38
kg) obviously increases the overall dimensions: height 21.80 cm, width
28 cm, depth 19.60 cm.
Judgement
Cast a netbook for mobility, thanks to long
HP
dv4 Battery life, good performance that does not disdain. We can
define Eee PC 1101HA netbook complete. In fact, the hardware
equipment enables to easily perform common office work in comfort.
With excellent value for money (currently about 360 million) this
netbook is among the best in its class.
