How to fix a tv with constant blinking green and orange lights:
If your TV has been constantly blinking green and orange lights, it is likely that there is a problem with the power supply. The first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet.
If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself.
If the power supply is the problem, then you will need to replace it.
How to fix tv with tv doesn't come on when plugged in:
If your TV doesn't come on when plugged in, the first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet.
If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself. If the power supply is the problem, then you will need to replace it.
If you can hear mechanical sounds from the case the problem is in the hard disk and moving it to your laptop isn't the solution. In that case check for a data recovery company at your area as sooner as posible. If the sound is no mechanical I'll tell you the way to move the HD. Describe me the kind of sound.
Constant +12volts Green/Yellow Switched +12volts Yellow/Black Ground Red Power antenna Blue Illumination Blue/Red
Speakers
Front Right + White/Green Front Right - Green/Orange Front Left + Orange/Green Front Left - Light Blue Rear Right + Pink/Blue Rear Right - Green/Orange Rear Left + Pink/Green Rear Left - Pink/Blue
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present. Just an idea?
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Constant 12V+
Black/Orange
Switched 12V+
Yellow/Black
Ground
Black/Light Green
Illumination
Light Green
Dimmer
n/a
Amplifier Remote
Dark Blue
Antenna
Right Front
Front Speakers
5" x 7" Doors
Left Front (+)
Orange/Light Green
Left Front (-)
Light Blue/White
Right Front (+)
White/Light Green
Right Front (-)
Dark Green/Orange
Rear Speakers
5" x 7" Side Panels
Left Rear (+)
Pink/Light Green
Left Rear (-)
Tan/Yellow
Right Rear (+)
Pink/Light Blue
Right Rear (-)
Brown/Pink
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+
White/Purple
Switched 12V+
Black/Pink
Ground
Black/Green
Illumination
Blue/Black
Dimmer
n/a
Amplifier Remote
Blue
Antenna
Right Front
Front Speakers
6" x 8" Doors
Left Front (+)
Light Blue/White
Left Front (-)
Orange/Light Green
Right Front (+)
Dark Green/Orange
Right Front (-)
White/Light Green
Rear Speakers
6" x 8" Rear Doors
Left Rear (+)
Tan/Yellow
Left Rear (-)
Gray/Light Blue
Right Rear (+)
Brown/Pink
Right Rear (-)
Orange/Red
1998 Ford Explorer Stereo Wiring
Constant 12V+
Light Green
Switched 12V+
Yellow/Black
Ground
Black
Illumination
Light Blue/Red
Dimmer
n/a
Antenna Trigger
Orange/Blue
Antenna
Right Front
Front Speakers
5" x 7" Doors
Left Front (+)
Orange/Light Green
Left Front (-)
Light Blue/White
Right Front (+)
Dark Green/Orange
Right Front (-)
White/Light Green
Rear Speakers
5" x 7" Rear Door
Left Rear (+)
Gray/Light Blue
Left Rear (-)
Tan/Yellow
Right Rear (+)
Orange/Red
Right Rear (-)
Brown/Pink
Heres the whole list.
1999 Ford Explorer
Constant 12V+ Light Green
Switched 12V+ Yellow/Black
Ground Black
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) Dark Green/Orange
Right Front (-) White/Light Green
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
(from the12volt.com)
Best of Luck.
